Salta al contenuto principale
HP EliteBook 8560w Hard Drive Replacement
Cosa ti serve
  1. HP EliteBook 8560w Hard Drive Replacement, Battery: passo 1, immagine 1 di 2 HP EliteBook 8560w Hard Drive Replacement, Battery: passo 1, immagine 2 di 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Hard Drive Replacement: passo 2, immagine 1 di 1
    • Pull the battery out.
  3. HP EliteBook 8560w Hard Drive Replacement, Back Panel: passo 3, immagine 1 di 2 HP EliteBook 8560w Hard Drive Replacement, Back Panel: passo 3, immagine 2 di 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Hard Drive Replacement: passo 4, immagine 1 di 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 2 HP EliteBook 8560w Hard Drive Replacement, Hard Drive: passo 5, immagine 2 di 2
    • Make sure your device is powered off and its battery removed.
    • Remove the four M2.5x8mm screws with Phillips #0 screwdriver and lift up the panel to access your Hard Drive.
  6. HP EliteBook 8560w Hard Drive Replacement: passo 6, immagine 1 di 3 HP EliteBook 8560w Hard Drive Replacement: passo 6, immagine 2 di 3 HP EliteBook 8560w Hard Drive Replacement: passo 6, immagine 3 di 3
    • Remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Slide the hard drive to the left and lift it to remove it.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 18
Tutti i Tempi: 1,874
