Salta al contenuto principale
HP EliteBook 8530w Heatsink Replacement
Cosa ti serve
  1. HP EliteBook 8530w Heatsink Replacement, Battery: passo 1, immagine 1 di 2 HP EliteBook 8530w Heatsink Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the laptop off then place it down so that the back is facing up.
    • Slide the battery release switch to the left and hold it there.
  2. HP EliteBook 8530w Heatsink Replacement: passo 2, immagine 1 di 2 HP EliteBook 8530w Heatsink Replacement: passo 2, immagine 2 di 2
    • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
    • Once the battery is removed from the laptop, you may release the switch.
    • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
  3. HP EliteBook 8530w Heatsink Replacement, Fan: passo 3, immagine 1 di 1
    • Unscrew the two screws from the center panel with a Phillips #00 screwdriver.
    • These screws should have a keyboard icon stamped next to them.
  4. HP EliteBook 8530w Heatsink Replacement: passo 4, immagine 1 di 3 HP EliteBook 8530w Heatsink Replacement: passo 4, immagine 2 di 3 HP EliteBook 8530w Heatsink Replacement: passo 4, immagine 3 di 3
    • Flip the laptop over then open the lid.
    • Slide the four tabs at the top of the keyboard towards you with your finger.
    • Wedge a finger or spudger in the top corner of the keyboard and hinge it forward to reveal the backside.
    • Do not try to pull the keyboard out of the laptop. There are still cables connected to it that can easily be damaged.
  5. HP EliteBook 8530w Heatsink Replacement: passo 5, immagine 1 di 3 HP EliteBook 8530w Heatsink Replacement: passo 5, immagine 2 di 3 HP EliteBook 8530w Heatsink Replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Use a Torx TR7 screwdriver to remove the three screws holding down the fan.
    • Gently remove the fan connector that plugs into the motherboard.
    • Note: It can help to use something like tweezers to remove the connector if you are having trouble.
    • Remove the fan.
  6. HP EliteBook 8530w Heatsink Replacement, Heatsink: passo 6, immagine 1 di 3 HP EliteBook 8530w Heatsink Replacement, Heatsink: passo 6, immagine 2 di 3 HP EliteBook 8530w Heatsink Replacement, Heatsink: passo 6, immagine 3 di 3
    • Remove the eight screws holding down the heat sink using a Torx TR7 bit.
    • Gently remove the heat sink by lifting it up and sliding it away from the side of the laptop.
    • The thermal paste will be situated on the small square portion of the heatsink that sat directly atop the CPU. Clean both the heatsink and CPU of the old thermal paste before application as shown in this guide.
Conclusione
Austin Blakely
Membro da: 03/11/19
21.226 Reputazione
53 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.434 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 662
