Salta al contenuto principale
HP EliteBook 850 G3 Fan Replacement
Cosa ti serve
  1. HP EliteBook 850 G3 Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Fan Replacement, Unscrew the bottom: passo 2, immagine 1 di 2 HP EliteBook 850 G3 Fan Replacement, Unscrew the bottom: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Fan Replacement: passo 3, immagine 1 di 2 HP EliteBook 850 G3 Fan Replacement: passo 3, immagine 2 di 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Fan Replacement, Remove the battery screws: passo 4, immagine 1 di 2 HP EliteBook 850 G3 Fan Replacement, Remove the battery screws: passo 4, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Fan Replacement, Lift the battery: passo 5, immagine 1 di 3 HP EliteBook 850 G3 Fan Replacement, Lift the battery: passo 5, immagine 2 di 3 HP EliteBook 850 G3 Fan Replacement, Lift the battery: passo 5, immagine 3 di 3
    • Lift and pull the flap located at the top of the battery to remove it.
  6. HP EliteBook 850 G3 Fan Replacement, Fan: passo 6, immagine 1 di 1
    • Gently unclip the plastic frame.
  7. HP EliteBook 850 G3 Fan Replacement: passo 7, immagine 1 di 3 HP EliteBook 850 G3 Fan Replacement: passo 7, immagine 2 di 3 HP EliteBook 850 G3 Fan Replacement: passo 7, immagine 3 di 3
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  8. HP EliteBook 850 G3 Fan Replacement: passo 8, immagine 1 di 2 HP EliteBook 850 G3 Fan Replacement: passo 8, immagine 2 di 2
    • Carefully remove the connector for the fan.
  9. HP EliteBook 850 G3 Fan Replacement: passo 9, immagine 1 di 3 HP EliteBook 850 G3 Fan Replacement: passo 9, immagine 2 di 3 HP EliteBook 850 G3 Fan Replacement: passo 9, immagine 3 di 3
    • Carefully remove the fan and heatsink assembly from the laptop.
Conclusione
USF Tampa, Team S1-G1, Leahy Fall 2019 Membro di USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 46
Tutti i Tempi: 2,514
