Salta al contenuto principale
HP EliteBook 820 G3 Keyboard Replacement
Cosa ti serve
  1. HP EliteBook 820 G3 Keyboard Replacement, Back Cover: passo 1, immagine 1 di 2 HP EliteBook 820 G3 Keyboard Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
  2. HP EliteBook 820 G3 Keyboard Replacement: passo 2, immagine 1 di 2 HP EliteBook 820 G3 Keyboard Replacement: passo 2, immagine 2 di 2
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
  3. HP EliteBook 820 G3 Keyboard Replacement, Keyboard: passo 3, immagine 1 di 2 HP EliteBook 820 G3 Keyboard Replacement, Keyboard: passo 3, immagine 2 di 2
    • Remove the two 3.4 mm keyboard screws found near the fan and on top of the hard drive using a Phillips #00 screwdriver.
  4. HP EliteBook 820 G3 Keyboard Replacement: passo 4, immagine 1 di 3 HP EliteBook 820 G3 Keyboard Replacement: passo 4, immagine 2 di 3 HP EliteBook 820 G3 Keyboard Replacement: passo 4, immagine 3 di 3
    • Use an iFixit opening pick to gently pry open the top of the keyboard.
    • Gently pull the keyboard up until you can see the three ribbons under the keyboard.
  5. HP EliteBook 820 G3 Keyboard Replacement: passo 5, immagine 1 di 3 HP EliteBook 820 G3 Keyboard Replacement: passo 5, immagine 2 di 3 HP EliteBook 820 G3 Keyboard Replacement: passo 5, immagine 3 di 3
    • Lift up the latch holding down the ribbon and pull the ribbon out once it is lifted.
    • Repeat for all three of the ribbons.
    • The white ribbon (left ribbon) sometimes does not come with a new keyboard. You may need to detach it and add it to the replacement if necessary.
Conclusione
Altre 4 persone hanno completato questa guida.
Caleb Morales
Membro da: 08/25/22
184 Reputazione
1 Guida realizzata
Gateway, Team 1-1, Class Fall 2022 Membro di Gateway, Team 1-1, Class Fall 2022
GCC-CLASS-F22S1G1
4 Membri
6 Guide realizzate
Un commento
I did this, it won’t stay in.
Serial Action - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 85
Tutti i Tempi: 1,700
