Salta al contenuto principale
HP Elite X2 1013 G3 Battery Replacement
Cosa ti serve
  1. HP Elite X2 1013 G3 Battery Replacement, Screen: passo 1, immagine 1 di 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Battery Replacement: passo 2, immagine 1 di 2 HP Elite X2 1013 G3 Battery Replacement: passo 2, immagine 2 di 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Battery Replacement: passo 3, immagine 1 di 2 HP Elite X2 1013 G3 Battery Replacement: passo 3, immagine 2 di 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Battery Replacement: passo 4, immagine 1 di 2 HP Elite X2 1013 G3 Battery Replacement: passo 4, immagine 2 di 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Battery Replacement, Battery: passo 5, immagine 1 di 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Battery Replacement: passo 6, immagine 1 di 1
    • Lift the battery out of the housing.
Conclusione
Asmita Sharma
Membro da: 04/18/19
186 Reputazione
1 Guida realizzata
Cal Poly, Team S9-G12, Maness Spring 2019 Membro di Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 63
Tutti i Tempi: 2,477
