Salta al contenuto principale
HP ENVY ×360 15-bp106ng RAM Replacement
Cosa ti serve
  1. HP ENVY ×360 15-bp106ng RAM Replacement, Shut down and turn over: passo 1, immagine 1 di 1
    • Shut down the laptop.
    • Turn it over and position it so that the display hinges face away from you.
  2. HP ENVY ×360 15-bp106ng RAM Replacement, Remove the exposed torx screws: passo 2, immagine 1 di 1
    • Remove the three exposed Torx T5 screws.
  3. HP ENVY ×360 15-bp106ng RAM Replacement, Remove back rubber strip: passo 3, immagine 1 di 1
    • Remove the rubber strip that is close to the display hinges.
    • Remove the adhesive strip along with the rubber to reveal the underlying screws.
  4. HP ENVY ×360 15-bp106ng RAM Replacement, Remove Phillips screws: passo 4, immagine 1 di 1
    • Remove the four Phillips P1 screws that are revealed by removing the rubber strip.
    • Note that the second screw hole from the right is not as deep as the other three.
  5. HP ENVY ×360 15-bp106ng RAM Replacement, Separate the housing: passo 5, immagine 1 di 3 HP ENVY ×360 15-bp106ng RAM Replacement, Separate the housing: passo 5, immagine 2 di 3 HP ENVY ×360 15-bp106ng RAM Replacement, Separate the housing: passo 5, immagine 3 di 3
    • Using an opening tool and opening picks, separate the bottom housing plate from the rest of the chassis on the left, bottom and right edges.
    • Lift and remove the plate.
  6. HP ENVY ×360 15-bp106ng RAM Replacement, Remove battery screws: passo 6, immagine 1 di 1
    • Remove the seven Phillips P1 screws that hold the battery in place.
    • Note that these battery screws have a different length than the P1 chassis screws.
  7. HP ENVY ×360 15-bp106ng RAM Replacement, Remove battery: passo 7, immagine 1 di 3 HP ENVY ×360 15-bp106ng RAM Replacement, Remove battery: passo 7, immagine 2 di 3 HP ENVY ×360 15-bp106ng RAM Replacement, Remove battery: passo 7, immagine 3 di 3
    • Using your hands, lift the battery up and towards yourself.
  8. HP ENVY ×360 15-bp106ng RAM Replacement, Remove tape from RAM housing: passo 8, immagine 1 di 1
    • Remove the black tape that is stuck to the large silver-black RAM housing.
  9. HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM housing: passo 9, immagine 1 di 3 HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM housing: passo 9, immagine 2 di 3 HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM housing: passo 9, immagine 3 di 3
    • Using a spudger, gently separate the RAM housing from the main board.
  10. HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM: passo 10, immagine 1 di 2 HP ENVY ×360 15-bp106ng RAM Replacement, Remove RAM: passo 10, immagine 2 di 2
    • Using both hands, bend outwards the two clips that hold the RAM module.
    • Remove the RAM module to the right and up.
    • Now insert the new RAM module, pushing it in from the right.
Conclusione
Altre 2 persone hanno completato questa guida.
Adrian
Membro da: 06/29/23
276 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 33
Tutti i Tempi: 2,233
