Salta al contenuto principale
HP Compaq 6710b Heat Sink Replacement
Cosa ti serve
  1. HP Compaq 6710b Heat Sink Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off your computer! Taking out the battery while it's still on is dangerous!
    • Flip the laptop over to the back.
    • Using two hands, push on the tabs while gently taking out the battery.
  2. HP Compaq 6710b Heat Sink Replacement, Keyboard: passo 2, immagine 1 di 3 HP Compaq 6710b Heat Sink Replacement, Keyboard: passo 2, immagine 2 di 3 HP Compaq 6710b Heat Sink Replacement, Keyboard: passo 2, immagine 3 di 3
    • Turn off computer before starting.
    • Flip to the backside of the laptop.
    • Using a Phillips #1 screwdriver, unscrew the 5mm screw and take off the shown cover.
    • Using the same screwdriver, unscrew the 8mm screws.
    • The screws may not completely fall out of the laptop, just ensure they are unscrewed as far as they will go.
  3. HP Compaq 6710b Heat Sink Replacement: passo 3, immagine 1 di 1
    • Flip over the laptop to the top side, and open the laptop.
    • Slide the locking tabs down using a blue plastic opening tool or your fingernail.
  4. HP Compaq 6710b Heat Sink Replacement: passo 4, immagine 1 di 2 HP Compaq 6710b Heat Sink Replacement: passo 4, immagine 2 di 2
    • Using the plastic prying tool, lift the keyboard gently towards you.
    • Don't take the keyboard completely off because it is still attached with a ribbon cable to the computer.
  5. HP Compaq 6710b Heat Sink Replacement: passo 5, immagine 1 di 1
    • Pull up on both sides of the black locking tab of the connector.
    • The keyboard should now be free of the computer.
  6. HP Compaq 6710b Heat Sink Replacement, Power Button Panel: passo 6, immagine 1 di 1
    • Put a finger under each side of the plastic lock on the ribbon cable and pull up.
    Reben pack Tut Gaya hai
    Gopal Ji - Replica
    Reben cabal tuta huahai
    Gopal Ji - Replica
  7. HP Compaq 6710b Heat Sink Replacement: passo 7, immagine 1 di 3 HP Compaq 6710b Heat Sink Replacement: passo 7, immagine 2 di 3 HP Compaq 6710b Heat Sink Replacement: passo 7, immagine 3 di 3
    • Using a flathead screwdriver, get under each plastic hinge cover until they pop.
    • Lift the right edge of plastic strip covering the power button and gently pull it up until the whole strip comes free.
  8. HP Compaq 6710b Heat Sink Replacement, Heat Sink: passo 8, immagine 1 di 1
    • Using two fingers, open the prongs holding the RAM
    • Then slide the RAM out from the socket
  9. HP Compaq 6710b Heat Sink Replacement: passo 9, immagine 1 di 1
    • Using a Phillips #1 screwdriver, unscrew the two 7mm screws on the top and bottom of the fan.
  10. HP Compaq 6710b Heat Sink Replacement: passo 10, immagine 1 di 3 HP Compaq 6710b Heat Sink Replacement: passo 10, immagine 2 di 3 HP Compaq 6710b Heat Sink Replacement: passo 10, immagine 3 di 3
    • Using two fingers, pull out the fan power connector.
    • To take out the fan, lift the bottom of the fan and take it out at an angle.
  11. HP Compaq 6710b Heat Sink Replacement: passo 11, immagine 1 di 1
    • Using the Phillips #1 screwdriver, unscrew the four screws on the copper plate.
    • The screws on the copper plate do not come all the way out.
  12. HP Compaq 6710b Heat Sink Replacement: passo 12, immagine 1 di 2 HP Compaq 6710b Heat Sink Replacement: passo 12, immagine 2 di 2
    • Rotate the copper plate heat sink to slide it out.
    • Do not force the heat sink because it's easy to damage.
Conclusione
Altre 9 persone hanno completato questa guida.
Khulan Orgil
Membro da: 04/14/15
1.171 Reputazione
6 Guide realizzate
Cal Poly, Team 4-2, Maness Spring 2015 Membro di Cal Poly, Team 4-2, Maness Spring 2015
CPSU-MANESS-S15S4G2
4 Membri
6 Guide realizzate
3Commenti sulla guida
That was easy. Thanks man :)
Florian Kasimir - Replica
благодаря за инструкцията!
kirovr - Replica
Piece of cake ! Thanks. :)
Pierre Delanoy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 28
Tutti i Tempi: 4,206
