Salta al contenuto principale
HP Chromebook CB2L Speaker Replacement
Cosa ti serve
  1. HP Chromebook CB2L Speaker Replacement, Battery: passo 1, immagine 1 di 2 HP Chromebook CB2L Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Speaker Replacement: passo 2, immagine 1 di 3 HP Chromebook CB2L Speaker Replacement: passo 2, immagine 2 di 3 HP Chromebook CB2L Speaker Replacement: passo 2, immagine 3 di 3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Speaker Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Speaker Replacement: passo 4, immagine 1 di 1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Speaker Replacement: passo 5, immagine 1 di 1
    • Using the plastic opening tool remove the battery from the Chromebook.
  6. HP Chromebook CB2L Speaker Replacement, Speaker: passo 6, immagine 1 di 1
    • Using the plastic opening tool lift the black tab.
    • Disconnect the blue and black strip from the motherboard.
  7. HP Chromebook CB2L Speaker Replacement: passo 7, immagine 1 di 1
    • Use the Phillips #1 screwdriver to remove the four 1.2mm screws circled red.
  8. HP Chromebook CB2L Speaker Replacement: passo 8, immagine 1 di 3 HP Chromebook CB2L Speaker Replacement: passo 8, immagine 2 di 3 HP Chromebook CB2L Speaker Replacement: passo 8, immagine 3 di 3
    • Gently pull the black wire to disconnect the audio port from the motherboard.
    • Disconnect the black wire connecting the speaker to the motherboard with caution.
  9. HP Chromebook CB2L Speaker Replacement: passo 9, immagine 1 di 1
    • Use the plastic opening tool to remove the speaker from back panel.
Conclusione
USF Tampa, Team S2-G6, Lacy Spring 2017 Membro di USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 157
