Introduzione
We are going to help you remove and replace a component of your HP Chromebook CB2L. The component that this guide helps you with is the Battery of the HP Chromebook CB2L. Please take a look at this troubleshooting page to confirm that this component needs replacement.
Cosa ti serve
First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
Next, using the plastic opening tool remove the blue panel.
Altre 3 persone hanno completato questa guida.
2 Commenti
the step about gently prying the underside of the laptop off made me snap off two screws under the thin blue rubber strip ! i see the holes they went in in the pictures in this guide. i understand that strip was glued on and it doesn't seem necessary to put those back (since i can't unglue the strip to put those screws back in) but.. yeah. it was unexpected and i thought i'd done something wrong.
Dont forget there are two screws underneath the small blue strip.
