Salta al contenuto principale
HP Chromebook CB2L Battery Replacement
Cosa ti serve
  1. HP Chromebook CB2L Battery Replacement, Battery: passo 1, immagine 1 di 2 HP Chromebook CB2L Battery Replacement, Battery: passo 1, immagine 2 di 2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Battery Replacement: passo 2, immagine 1 di 3 HP Chromebook CB2L Battery Replacement: passo 2, immagine 2 di 3 HP Chromebook CB2L Battery Replacement: passo 2, immagine 3 di 3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Battery Replacement: passo 3, immagine 1 di 1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Battery Replacement: passo 4, immagine 1 di 1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Battery Replacement: passo 5, immagine 1 di 1
    • Using the plastic opening tool remove the battery from the Chromebook.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team S2-G6, Lacy Spring 2017 Membro di USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 Membri
4 Guide realizzate
2 Commenti
the step about gently prying the underside of the laptop off made me snap off two screws under the thin blue rubber strip ! i see the holes they went in in the pictures in this guide. i understand that strip was glued on and it doesn't seem necessary to put those back (since i can't unglue the strip to put those screws back in) but.. yeah. it was unexpected and i thought i'd done something wrong.
katie - Replica
Dont forget there are two screws underneath the small blue strip.
Roderick Wells - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,422
