Salta al contenuto principale
HP Chromebook 14-q063cl Keyboard Replacement
Cosa ti serve
  1. HP Chromebook 14-q063cl Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 HP Chromebook 14-q063cl Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 HP Chromebook 14-q063cl Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Flip the laptop upside down so that the bottom is facing upwards.
    • Use Phillips #0 screwdriver to remove nine 6.7 mm screws from the bottom panel.
  2. HP Chromebook 14-q063cl Keyboard Replacement: passo 2, immagine 1 di 3 HP Chromebook 14-q063cl Keyboard Replacement: passo 2, immagine 2 di 3 HP Chromebook 14-q063cl Keyboard Replacement: passo 2, immagine 3 di 3
    • Use a metal spudger to pry the plastic covers off four additional screws.
  3. HP Chromebook 14-q063cl Keyboard Replacement: passo 3, immagine 1 di 3 HP Chromebook 14-q063cl Keyboard Replacement: passo 3, immagine 2 di 3 HP Chromebook 14-q063cl Keyboard Replacement: passo 3, immagine 3 di 3
    • Use a Phillips #0 screwdriver to remove the four remaining 6.7 mm screws from the bottom panel.
  4. HP Chromebook 14-q063cl Keyboard Replacement: passo 4, immagine 1 di 3 HP Chromebook 14-q063cl Keyboard Replacement: passo 4, immagine 2 di 3 HP Chromebook 14-q063cl Keyboard Replacement: passo 4, immagine 3 di 3
    • Turn the laptop upright.
    • Use an opening tool or picks to undo the clips around the perimeter of the keyboard assembly and separate it from the rest of the laptop.
    • Remove the keyboard assembly.
    • Disconnect the cable attaching the keyboard cable to the motherboard.
    • Use caution when removing the keyboard assembly so as to not break it or rip any cables or connectors attached to the board. Don't yank the keyboard assembly from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 121
