Salta al contenuto principale
HP Chromebook 14-q029wm Fan Replacement
Cosa ti serve
  1. HP Chromebook 14-q029wm Fan Replacement, Keyboard: passo 1, immagine 1 di 1
    • Remove nine 5mm Phillips #0 screws from the back case.
    • Remove the rubber caps using a spudger.
    • Remove the four remaining 5mm Phillips #0 screws.
  2. HP Chromebook 14-q029wm Fan Replacement: passo 2, immagine 1 di 1
    • Use an opening tool to unclip the bottom plastic covering of the laptop.
    • Go around the sides of the laptop until the bottom unclips completely and comes off of the laptop.
    • Be careful not to break the plastic clips.
  3. HP Chromebook 14-q029wm Fan Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Once the bottom is completely unclipped, remove the covering slowly so you do not pull and rip the wires.
    • There is a little black lever that you have to pull in order to remove the wires. They are found on top of where the wires are connected.
    • Remove the larger wire first.
    • Then remove the smaller wire.
    • It is better to use a pair of tweezers for accuracy
    • From there the keyboard should completely come off.
  4. HP Chromebook 14-q029wm Fan Replacement, Battery: passo 4, immagine 1 di 1
    • Use your fingers to pull the white tab out of the black slot above the battery.
  5. HP Chromebook 14-q029wm Fan Replacement: passo 5, immagine 1 di 1
    • Remove the 3mm Phillips #0 screws.
  6. HP Chromebook 14-q029wm Fan Replacement: passo 6, immagine 1 di 1
    • Pick up and gently remove the battery.
  7. HP Chromebook 14-q029wm Fan Replacement, Fan: passo 7, immagine 1 di 2 HP Chromebook 14-q029wm Fan Replacement, Fan: passo 7, immagine 2 di 2
    • Remove the three 3mm Phillips #0 screws.
    • The bottom right screw may be covered by the fan's wires.
  8. HP Chromebook 14-q029wm Fan Replacement: passo 8, immagine 1 di 1
    • Using your fingers or an opening tool, remove the cable connecting the fan to the motherboard.
    • Gently remove the fan.
Conclusione
Altre 2 persone hanno completato questa guida.
Andrew Pratt
Membro da: 11/05/19
669 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 15
Tutti i Tempi: 312
