Salta al contenuto principale
HP 15-f004dx RAM Replacement
Cosa ti serve
  1. HP 15-f004dx RAM Replacement, RAM: passo 1, immagine 1 di 1
    • Flip laptop over to the back, so that the stickers are showing and the RAM panel is facing up.
  2. HP 15-f004dx RAM Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #0 screwdriver to unscrew the two 2mm RAM shield screws from the bottom of the laptop.
  3. HP 15-f004dx RAM Replacement: passo 3, immagine 1 di 3 HP 15-f004dx RAM Replacement: passo 3, immagine 2 di 3 HP 15-f004dx RAM Replacement: passo 3, immagine 3 di 3
    • Remove the RAM shield.
    • Small brackets secure the RAM. Push the brackets to the side to free the RAM.
  4. HP 15-f004dx RAM Replacement: passo 4, immagine 1 di 2 HP 15-f004dx RAM Replacement: passo 4, immagine 2 di 2
    • The RAM card should now pop up out of its slot. Remove the RAM.
    • Next, you will replace/reseat the memory modules following steps 3 and 4 in reverse. Once you have completed that, you can now power on the computer to test and see if reseating/replacing the RAM has resolved the problem.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 723
