Salta al contenuto principale
HP 15-ef Rubber Feet Replacement
Cosa ti serve
  1. HP 15-ef Rubber Feet Replacement, Flip your laptop over: passo 1, immagine 1 di 1
    • Flip your laptop over so the rubber feet are facing up.
  2. HP 15-ef Rubber Feet Replacement, Peel up an end of the front foot: passo 2, immagine 1 di 3 HP 15-ef Rubber Feet Replacement, Peel up an end of the front foot: passo 2, immagine 2 di 3 HP 15-ef Rubber Feet Replacement, Peel up an end of the front foot: passo 2, immagine 3 di 3
    • The rubber feet cover a total of six back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
  3. HP 15-ef Rubber Feet Replacement, Remove the front foot: passo 3, immagine 1 di 3 HP 15-ef Rubber Feet Replacement, Remove the front foot: passo 3, immagine 2 di 3 HP 15-ef Rubber Feet Replacement, Remove the front foot: passo 3, immagine 3 di 3
    • Peel the front foot away from the back cover and remove it.
  4. HP 15-ef Rubber Feet Replacement, Remove the rear foot: passo 4, immagine 1 di 3 HP 15-ef Rubber Feet Replacement, Remove the rear foot: passo 4, immagine 2 di 3 HP 15-ef Rubber Feet Replacement, Remove the rear foot: passo 4, immagine 3 di 3
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
  5. HP 15-ef Rubber Feet Replacement, Reassembly information: passo 5, immagine 1 di 3 HP 15-ef Rubber Feet Replacement, Reassembly information: passo 5, immagine 2 di 3 HP 15-ef Rubber Feet Replacement, Reassembly information: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Tesa 61395 Tape
    $5.99
    Compra
    • Note that the rubber feet are different:
    • The rear foot is thicker, with a deeper recess.
    • The front foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
Conclusione
Spencer Day
Membro da: 09/14/22
61.613 Reputazione
445 Guide realizzate
iFixit Membro di iFixit
Staff
140 Membri
18.085 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 44
Tutti i Tempi: 872
