Salta al contenuto principale
HP 15-bs168cl Fan Replacement
Cosa ti serve
  1. HP 15-bs168cl Fan Replacement, Battery: passo 1, immagine 1 di 2 HP 15-bs168cl Fan Replacement, Battery: passo 1, immagine 2 di 2
    • Unplug your laptop from its power adapter.
    • Turn the laptop over.
  2. HP 15-bs168cl Fan Replacement: passo 2, immagine 1 di 2 HP 15-bs168cl Fan Replacement: passo 2, immagine 2 di 2
    • Slide the Battery lock slider to the right until you see the “Unlocked” lock symbol.
  3. HP 15-bs168cl Fan Replacement: passo 3, immagine 1 di 2 HP 15-bs168cl Fan Replacement: passo 3, immagine 2 di 2
    • Slide the Battery release slider towards the battery while pulling the battery out.
  4. HP 15-bs168cl Fan Replacement, Fan: passo 4, immagine 1 di 2 HP 15-bs168cl Fan Replacement, Fan: passo 4, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the six 10.5 mm screws visible on the bottom of the laptop.
  5. HP 15-bs168cl Fan Replacement: passo 5, immagine 1 di 2 HP 15-bs168cl Fan Replacement: passo 5, immagine 2 di 2
    • Carefully peel the four rubber feet off the bottom to reveal the four hidden screws.
    • Use a Phillips #1 screwdriver to remove the four 10.5 mm screws.
  6. HP 15-bs168cl Fan Replacement: passo 6, immagine 1 di 1
    • Remove the DVD drive by carefully sliding it out.
  7. HP 15-bs168cl Fan Replacement: passo 7, immagine 1 di 3 HP 15-bs168cl Fan Replacement: passo 7, immagine 2 di 3 HP 15-bs168cl Fan Replacement: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    • Flip the laptop over and open the screen.
    • Carefully use a flat plastic card to separate the bottom plastic shell from the main body of the computer. Slowly slide the plastic card around the computer in between the two halves of its casing.
    • Flip the computer back over and remove the bottom plastic shell.
  8. HP 15-bs168cl Fan Replacement: passo 8, immagine 1 di 2 HP 15-bs168cl Fan Replacement: passo 8, immagine 2 di 2
    • Using a Phillips #1 screwdriver remove the screw from the Wi-fi card.
    • Remove the card.
  9. HP 15-bs168cl Fan Replacement: passo 9, immagine 1 di 2 HP 15-bs168cl Fan Replacement: passo 9, immagine 2 di 2
    • Carefully unplug the LCD connector using a plastic spudger.
  10. HP 15-bs168cl Fan Replacement: passo 10, immagine 1 di 2 HP 15-bs168cl Fan Replacement: passo 10, immagine 2 di 2
    • Unplug the power connector.
  11. HP 15-bs168cl Fan Replacement: passo 11, immagine 1 di 3 HP 15-bs168cl Fan Replacement: passo 11, immagine 2 di 3 HP 15-bs168cl Fan Replacement: passo 11, immagine 3 di 3
    • Pull all three cables to the side to reveal the 6.7 mm screw attached to the fan.
    • Remove the screw with a Phillips #0 screwdriver.
    • Unplug the fan connector.
    • Pull out the fan carefully leaving the heatsink in place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 13
Tutti i Tempi: 775
