Salta al contenuto principale
HP 15-ay114cy Screen Replacement
Cosa ti serve
  1. HP 15-ay114cy Screen Replacement, Orient the Laptop: passo 1, immagine 1 di 1
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Screen Replacement, Push out the Battery: passo 2, immagine 1 di 2 HP 15-ay114cy Screen Replacement, Push out the Battery: passo 2, immagine 2 di 2
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Screen Replacement, Remove the Battery: passo 3, immagine 1 di 2 HP 15-ay114cy Screen Replacement, Remove the Battery: passo 3, immagine 2 di 2
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
  4. HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: passo 4, immagine 1 di 2 HP 15-ay114cy Screen Replacement, Remove the Plastic Frame: passo 4, immagine 2 di 2
    • Insert the flat end of the plastic opening tool between the screen and plastic frame.
    • Use the plastic opening tool to carefully pry the plastic frame off of the screen, starting in the middle and moving towards the corners.
  5. HP 15-ay114cy Screen Replacement, Remove the Screen: passo 5, immagine 1 di 3 HP 15-ay114cy Screen Replacement, Remove the Screen: passo 5, immagine 2 di 3 HP 15-ay114cy Screen Replacement, Remove the Screen: passo 5, immagine 3 di 3
    • Use the #00 Phillips-head screwdriver to remove the four 3 mm screws in each corner and carefully detach the screen and lay it onto the keyboard.
  6. HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: passo 6, immagine 1 di 3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: passo 6, immagine 2 di 3 HP 15-ay114cy Screen Replacement, Remove the Metal Display Connector: passo 6, immagine 3 di 3
    • Use your thumb and pointer finger to cautiously remove the display connector from the metal frame.
Conclusione
S20S3G#1 Membro di S20S3G#1
Local Repair Groups
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 321
