Salta al contenuto principale
HP 15-ay114cy Battery Replacement
  1. HP 15-ay114cy Battery Replacement, Orient the Laptop: passo 1, immagine 1 di 1
    • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
    • Ensure the laptop is powered off before moving forward.
  2. HP 15-ay114cy Battery Replacement, Push out the Battery: passo 2, immagine 1 di 2 HP 15-ay114cy Battery Replacement, Push out the Battery: passo 2, immagine 2 di 2
    • Place your index fingers on each of the two battery holder clips.
    • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
  3. HP 15-ay114cy Battery Replacement, Remove the Battery: passo 3, immagine 1 di 2 HP 15-ay114cy Battery Replacement, Remove the Battery: passo 3, immagine 2 di 2
    • After the battery clips are pushed in, use either hand to grab hold of the battery.
    • Gently push up to remove the battery.
Conclusione
S20S3G#1 Membro di S20S3G#1
Local Repair Groups
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 282
