Salta al contenuto principale
HP 15-ay078nr Fan Replacement
Cosa ti serve
  1. HP 15-ay078nr Fan Replacement, Battery: passo 1, immagine 1 di 1
    • Orient the laptop so that the underside is facing up.
    • Rotate the device so that the CD slot is in the upper left corner.
  2. HP 15-ay078nr Fan Replacement: passo 2, immagine 1 di 2 HP 15-ay078nr Fan Replacement: passo 2, immagine 2 di 2
    • Put your fingers on the battery latch.
  3. HP 15-ay078nr Fan Replacement: passo 3, immagine 1 di 2 HP 15-ay078nr Fan Replacement: passo 3, immagine 2 di 2
    • Using your fingers, push each battery latch simultaneously towards the middle.
    • This releases the battery.
    • Remove the battery from the laptop.
  4. HP 15-ay078nr Fan Replacement, Back Panel: passo 4, immagine 1 di 2 HP 15-ay078nr Fan Replacement, Back Panel: passo 4, immagine 2 di 2
    • Pull off the two rubber feet on the underside of the device.
    • Remove the twelve 9.5 mm screws from the underside of the device using a Phillips #2 screwdriver.
  5. HP 15-ay078nr Fan Replacement: passo 5, immagine 1 di 1
    • Slide an opening pick around the edges between the back panel and the rest of the device to release the plastic retention clips that hold the panel in place.
  6. HP 15-ay078nr Fan Replacement: passo 6, immagine 1 di 1
    • Lift up on the panel to remove it completely from the device.
  7. HP 15-ay078nr Fan Replacement, Fan: passo 7, immagine 1 di 1
    • Unplug the fan cable from the connector on the motherboard.
  8. HP 15-ay078nr Fan Replacement: passo 8, immagine 1 di 2 HP 15-ay078nr Fan Replacement: passo 8, immagine 2 di 2
    • Remove two 3.4 mm screws from the fan using a Phillips #2 screwdriver.
  9. HP 15-ay078nr Fan Replacement: passo 9, immagine 1 di 1
    • Lift up and remove the fan from the laptop.
Conclusione
Turn on the device and use it for several minutes for the device to come to operating temperature. Note how the bottom of the device feels, as it will be cooler than before the replacement was preformed. The response time after continuous use will be improved as well.
Bryce Getchell
Membro da: 10/25/21
315 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 190
