Salta al contenuto principale
HP 14-fq1025nr Ports Replacement
Cosa ti serve
  1. HP 14-fq1025nr Ports Replacement, Back Cover: passo 1, immagine 1 di 1
    • Flip the laptop upside down so the bottom cover is facing up.
  2. HP 14-fq1025nr Ports Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use a pair of tweezers to grab and pull the feet off of the cover.
  3. HP 14-fq1025nr Ports Replacement: passo 3, immagine 1 di 1
    • Remove the two 4 mm screws using a Phillips #0 screwdriver.
    • Remove the six remaining 6 mm screws located around the edges and underneath the feet using a Phillips #0 screwdriver.
  4. HP 14-fq1025nr Ports Replacement: passo 4, immagine 1 di 1
    • Flip the laptop right-side up and slide an iFixit opening tool and/or Jimmy inside of the bottom cover seam to pry it open.
  5. HP 14-fq1025nr Ports Replacement: passo 5, immagine 1 di 1
    • Remove the bottom cover.
  6. HP 14-fq1025nr Ports Replacement, Battery: passo 6, immagine 1 di 2 HP 14-fq1025nr Ports Replacement, Battery: passo 6, immagine 2 di 2
    • Remove the four gray 3 mm screws holding down the battery using a Phillips #0 screwdriver.
  7. HP 14-fq1025nr Ports Replacement: passo 7, immagine 1 di 1
    • Remove the battery.
  8. HP 14-fq1025nr Ports Replacement, Fan: passo 8, immagine 1 di 1
    • Remove the three silver screws (one 2 mm screw and two 4 mm screws) holding down the fan using a Phillips #0 screwdriver.
  9. HP 14-fq1025nr Ports Replacement: passo 9, immagine 1 di 1
    Compra
    • Unplug the fan’s power cord from the motherboard.
    • Use tweezers to pull the plug out, if needed.
  10. HP 14-fq1025nr Ports Replacement: passo 10, immagine 1 di 1
    • Remove the fan.
  11. HP 14-fq1025nr Ports Replacement, Motherboard: passo 11, immagine 1 di 3 HP 14-fq1025nr Ports Replacement, Motherboard: passo 11, immagine 2 di 3 HP 14-fq1025nr Ports Replacement, Motherboard: passo 11, immagine 3 di 3
    • Remove the five 3 mm gray screws from around the motherboard using a Phillips #00 screwdriver.
  12. HP 14-fq1025nr Ports Replacement: passo 12, immagine 1 di 2 HP 14-fq1025nr Ports Replacement: passo 12, immagine 2 di 2
    Compra
    • Unplug the wire connections.
    • Use tweezers if needed.
  13. HP 14-fq1025nr Ports Replacement: passo 13, immagine 1 di 1
    • Remove the motherboard.
    • Use the iFixit opening tool to pry it out if needed.
  14. HP 14-fq1025nr Ports Replacement, Ports: passo 14, immagine 1 di 1
Conclusione
Alex Cutler
Membro da: 09/26/22
301 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 10
Tutti i Tempi: 111
