Salta al contenuto principale
HMDX Chill Motherboard Replacement
Cosa ti serve
  1. HMDX Chill Motherboard Replacement, Remove Rubber Base: passo 1, immagine 1 di 3 HMDX Chill Motherboard Replacement, Remove Rubber Base: passo 1, immagine 2 di 3 HMDX Chill Motherboard Replacement, Remove Rubber Base: passo 1, immagine 3 di 3
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Motherboard Replacement: passo 2, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Motherboard Replacement: passo 3, immagine 1 di 2 HMDX Chill Motherboard Replacement: passo 3, immagine 2 di 2
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
  4. HMDX Chill Motherboard Replacement, Motherboard: passo 4, immagine 1 di 3 HMDX Chill Motherboard Replacement, Motherboard: passo 4, immagine 2 di 3 HMDX Chill Motherboard Replacement, Motherboard: passo 4, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
  5. HMDX Chill Motherboard Replacement: passo 5, immagine 1 di 1
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
  6. HMDX Chill Motherboard Replacement: passo 6, immagine 1 di 3 HMDX Chill Motherboard Replacement: passo 6, immagine 2 di 3 HMDX Chill Motherboard Replacement: passo 6, immagine 3 di 3
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
  7. HMDX Chill Motherboard Replacement: passo 7, immagine 1 di 2 HMDX Chill Motherboard Replacement: passo 7, immagine 2 di 2
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
  8. HMDX Chill Motherboard Replacement: passo 8, immagine 1 di 1
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
Conclusione
EWU-Giguere-S16S1G1 Membro di EWU-Giguere-S16S1G1
Community
4 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 414
