Salta al contenuto principale
GravityLight Motor Replacement
Cosa ti serve
  1. GravityLight Motor Replacement, Removing the Front Panel: passo 1, immagine 1 di 2 GravityLight Motor Replacement, Removing the Front Panel: passo 1, immagine 2 di 2
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Motor Replacement, Opening the Device Housing: passo 2, immagine 1 di 1
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Motor Replacement, Isolating the Back Panel: passo 3, immagine 1 di 1
    • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
  4. GravityLight Motor Replacement, Removing the Back Panel Screws: passo 4, immagine 1 di 1
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  5. GravityLight Motor Replacement, Removing the LED Housing: passo 5, immagine 1 di 1
    • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
    • Gently lift off the LED housing (the white disk).
    • Set the LED housing on the table next to the body of the device.
  6. GravityLight Motor Replacement, Removing White Frame and Gear: passo 6, immagine 1 di 1
    • Lift off the white piece with four arms.
    • Lift off the black-rimmed gear.
    • Set both pieces aside in a safe place.
  7. GravityLight Motor Replacement, Removing the Motor Screws: passo 7, immagine 1 di 1
    • Remove the two 2cm Phillips 00 screws from the motor housing.
    • The spring pushing the motor housing may pop out once the motor has been removed.
  8. GravityLight Motor Replacement, Separating the Back Panel Housing: passo 8, immagine 1 di 3 GravityLight Motor Replacement, Separating the Back Panel Housing: passo 8, immagine 2 di 3 GravityLight Motor Replacement, Separating the Back Panel Housing: passo 8, immagine 3 di 3
    • Firmly grasp both parts of the back panel and pull them apart.
  9. GravityLight Motor Replacement, Removing the Motor: passo 9, immagine 1 di 3 GravityLight Motor Replacement, Removing the Motor: passo 9, immagine 2 di 3 GravityLight Motor Replacement, Removing the Motor: passo 9, immagine 3 di 3
    • Place the middle section flat with the side that holds the gear system down and locate the back of the motor.
    • Clip the wires close to the soldered joints.
    • Lift the motor out of the middle section. Using the flush wire cutters, clip the red and the blue wires located on the motor's back.
  10. GravityLight Motor Replacement, Soldering the New Motor: passo 10, immagine 1 di 1
Conclusione
Cal Poly, Team 12-2, Forte Fall 2014 Membro di Cal Poly, Team 12-2, Forte Fall 2014
CPSU-FORTE-F14S12G2
5 Membri
7 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,318
