Salta al contenuto principale
Gigabyte P34G Hard Drive Replacement
Cosa ti serve
  1. Gigabyte P34G Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 1
    • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
    • There are three different sized screws.
    • 1x 9.8mm Screw
    • 8x 5.6mm Screws
    • 6x 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
  2. Gigabyte P34G Hard Drive Replacement: passo 2, immagine 1 di 2 Gigabyte P34G Hard Drive Replacement: passo 2, immagine 2 di 2
    • Carefully peel back the two pieces of black tape holding down the cord.
    • Pull the marked tab straight up away from the board to disconnect the hard drive from the board.
  3. Gigabyte P34G Hard Drive Replacement: passo 3, immagine 1 di 1
    • Carefully lift the hard drive for removal.
Conclusione
yeunghayden
Membro da: 05/01/15
841 Reputazione
6 Guide realizzate
Cal Poly, Team 8-1, Regan Spring 2015 Membro di Cal Poly, Team 8-1, Regan Spring 2015
CPSU-REGAN-S15S8G1
5 Membri
12 Guide realizzate
Un commento
Hi.
Can you please show me how to remove the back cover on the gigabyte sabre 17 laptop?
Need to change the hdd but cannot open the back.
Thank you.
Rizwan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 21
Tutti i Tempi: 3,420
