Salta al contenuto principale
GermGuardian AC4825E UV-C Bulb Replacement
Cosa ti serve
  1. GermGuardian AC4825E UV-C Bulb Replacement, HEPA Filter Unit: passo 1, immagine 1 di 1
    • Check if the purifier's power cord is plugged into an electrical outlet.
    • If it is plugged in, unplug the power cord.
  2. GermGuardian AC4825E UV-C Bulb Replacement: passo 2, immagine 1 di 2 GermGuardian AC4825E UV-C Bulb Replacement: passo 2, immagine 2 di 2
    • Grab the rear cover of the purifier with one finger on the Lock and Release button.
    • Press the button down, and pull the rear cover away from the purifier.
  3. GermGuardian AC4825E UV-C Bulb Replacement: passo 3, immagine 1 di 3 GermGuardian AC4825E UV-C Bulb Replacement: passo 3, immagine 2 di 3 GermGuardian AC4825E UV-C Bulb Replacement: passo 3, immagine 3 di 3
    • Use your hands to pull the HEPA filter out of the purifier.
    • After reassembly, push & hold the UV control button for 5 seconds to reset the filter change indicator.
  4. GermGuardian AC4825E UV-C Bulb Replacement, UV-C Bulb: passo 4, immagine 1 di 1
    • Remove the two screws from the metal UV-C shield by turning the screws counter-clockwise using a Phillips #00 screwdriver.
    • Grab and pull the UV-C shield away from the purifier to remove it.
  5. GermGuardian AC4825E UV-C Bulb Replacement: passo 5, immagine 1 di 3 GermGuardian AC4825E UV-C Bulb Replacement: passo 5, immagine 2 di 3 GermGuardian AC4825E UV-C Bulb Replacement: passo 5, immagine 3 di 3
    • Using a tissue or a clean cloth, reach into the exposed space and grab the UV-C bulb.
    • Pull the UV-C bulb out of the exposed space to remove the bulb from its socket.
    • After reassembly, press and hold the UV control button for 5 seconds to reset the UV bulb change indicator.
Conclusione
Altre 2 persone hanno completato questa guida.
Tim Lourenco
Membro da: 03/28/22
329 Reputazione
2 Guide realizzate
1Commento della guida
you end after you pull the bulb out. do you put another bulb in (of course) is there a right/wrong way (which side up or down) then do you plug it back in prior to holding the uv button 5 seconds? do you turn it on prior to holding the uv button 5 seconds? Please explain in detail what I should do.
william estes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 59
Tutti i Tempi: 2,473
