Salta al contenuto principale
Garmin inReach Explorer Plus LCD Screen Replacement
Cosa ti serve
  1. Garmin inReach Explorer Plus LCD Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Using the TR6 Torx Security screwdriver, remove six 10 mm screws from the back cover of the device.
  2. Garmin inReach Explorer Plus LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the back cover.
  3. Garmin inReach Explorer Plus LCD Screen Replacement: passo 3, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement: passo 3, immagine 2 di 2
    • Gently grasp the battery wire and disconnect it from the device.
    • Remove the battery from the device.
  4. Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: passo 4, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement, Motherboard: passo 4, immagine 2 di 2
    • Using the T5 Torx screwdriver, remove the six 6 mm screws from the motherboard.
  5. Garmin inReach Explorer Plus LCD Screen Replacement: passo 5, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement: passo 5, immagine 2 di 2
    • Disconnect the LCD screen from the motherboard by lifting on the flap with the nylon spudger.
    • The metal spudger should only be used for serious prying power. If used incorrectly, the metal spudger may damage the components of a device.
  6. Garmin inReach Explorer Plus LCD Screen Replacement: passo 6, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement: passo 6, immagine 2 di 2
    • Disconnect the antenna from the motherboard by lifting the wire with a nylon spudger.
  7. Garmin inReach Explorer Plus LCD Screen Replacement: passo 7, immagine 1 di 3 Garmin inReach Explorer Plus LCD Screen Replacement: passo 7, immagine 2 di 3 Garmin inReach Explorer Plus LCD Screen Replacement: passo 7, immagine 3 di 3
    • Gently lift the motherboard up and out of the device.
  8. Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: passo 8, immagine 1 di 2 Garmin inReach Explorer Plus LCD Screen Replacement, LCD Screen: passo 8, immagine 2 di 2
    • Using the T5 Torx screwdriver, remove the two 6 mm screws from the LCD screen.
  9. Garmin inReach Explorer Plus LCD Screen Replacement: passo 9, immagine 1 di 3 Garmin inReach Explorer Plus LCD Screen Replacement: passo 9, immagine 2 di 3 Garmin inReach Explorer Plus LCD Screen Replacement: passo 9, immagine 3 di 3
    • Use a nylon spudger to separate the LCD screen from the main body and remove the LCD screen.
Conclusione
Sean Kelley
Membro da: 09/28/21
387 Reputazione
4 Guide realizzate
Clemson, Team 5-4, Hunter Fall 2021 Membro di Clemson, Team 5-4, Hunter Fall 2021
CLEM-HUNTER-F21S5G4
4 Membri
5 Guide realizzate
3Commenti sulla guida
Where do I purchase the replacement LCD screen?
Tyler Lawrence - Replica
Ditto - where can we get a screen??
Ben Wallbank - Replica
Yes where can LCD SCREEN BE BOUGHT
Roy Shields - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,435
