Salta al contenuto principale
Garmin Nuvi 42LM Screen Replacement
Cosa ti serve
  1. Garmin Nuvi 42LM Screen Replacement, Back Cover: passo 1, immagine 1 di 3 Garmin Nuvi 42LM Screen Replacement, Back Cover: passo 1, immagine 2 di 3 Garmin Nuvi 42LM Screen Replacement, Back Cover: passo 1, immagine 3 di 3
    • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
  2. Garmin Nuvi 42LM Screen Replacement: passo 2, immagine 1 di 3 Garmin Nuvi 42LM Screen Replacement: passo 2, immagine 2 di 3 Garmin Nuvi 42LM Screen Replacement: passo 2, immagine 3 di 3
    • Pry the GPS open using a plastic opening tool.
    • When prying open the device, use caution to avoid damaging the motherboard.
  3. Garmin Nuvi 42LM Screen Replacement, Motherboard: passo 3, immagine 1 di 3 Garmin Nuvi 42LM Screen Replacement, Motherboard: passo 3, immagine 2 di 3 Garmin Nuvi 42LM Screen Replacement, Motherboard: passo 3, immagine 3 di 3
    • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
    • There are two screws - one in the back and one in the front.
  4. Garmin Nuvi 42LM Screen Replacement: passo 4, immagine 1 di 1
    • Move the motherboard from from its designated location on the GPS.
    • Do not pull on red, green, and black cables when repositioning the motherboard.
  5. Garmin Nuvi 42LM Screen Replacement: passo 5, immagine 1 di 2 Garmin Nuvi 42LM Screen Replacement: passo 5, immagine 2 di 2
    • Gently unplug the red, green, and black bundled cable to remove the battery.
  6. Garmin Nuvi 42LM Screen Replacement: passo 6, immagine 1 di 2 Garmin Nuvi 42LM Screen Replacement: passo 6, immagine 2 di 2
    • Use blue plastic opening tool to carefully pry the battery from the GPS.
    • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
  7. Garmin Nuvi 42LM Screen Replacement: passo 7, immagine 1 di 1
    • Using a soldering iron, desolder the black and blue wires connected to the motherboard.
    • Once the black and blue wires are desoldered, llift the motherboard out and away from the device.
    • Check out this awesome guide on how to solder and desolder connections.
  8. Garmin Nuvi 42LM Screen Replacement, Screen: passo 8, immagine 1 di 2 Garmin Nuvi 42LM Screen Replacement, Screen: passo 8, immagine 2 di 2
    • Push out the screen by pulling back the black clips.
    • The screen is attached to the motherboard and needs to be replaced with it.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Where do I purchase the screen for the Nuvi 42LM?
DR ROGER BROWNE - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 495
