Salta al contenuto principale
Garmin Nuvi 370 Microphone Replacement
Cosa ti serve
  1. Garmin Nuvi 370 Microphone Replacement, Microphone: passo 1, immagine 1 di 1
    • After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
  2. Garmin Nuvi 370 Microphone Replacement: passo 2, immagine 1 di 2 Garmin Nuvi 370 Microphone Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use the tweezers or the spudger to lift the tan latch off the ribbon cable (ZIF connector)and gently pull out the ZIF connector and cable from underneath the opened latch.
  3. Garmin Nuvi 370 Microphone Replacement: passo 3, immagine 1 di 2 Garmin Nuvi 370 Microphone Replacement: passo 3, immagine 2 di 2
    • The motherboard will now freely separate from the back casing; lay it flat next to the housing.
  4. Garmin Nuvi 370 Microphone Replacement: passo 4, immagine 1 di 2 Garmin Nuvi 370 Microphone Replacement: passo 4, immagine 2 di 2
    • Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
    • This step is optional but is recommended as it will create more room to work.
    • It is recommended that you use tweezers or the spudger for precision.
  5. Garmin Nuvi 370 Microphone Replacement: passo 5, immagine 1 di 1
    • Gently pull out the microphone wire from the terminal. Tweezers are recommended for precision.
  6. Garmin Nuvi 370 Microphone Replacement: passo 6, immagine 1 di 1
    • The microphone component should now be completely separated from the motherboard.
    • Plug in new, functional microphone component.
Linea Traguardo
Matt West
Membro da: 04/18/13
31 Reputazione
4 Guide realizzate
Cal Poly, Team 13-65, Johann Spring 2013 Membro di Cal Poly, Team 13-65, Johann Spring 2013
CPSU-JOHANN-S13S13G65
3 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 420
