Introduzione
This guide walks through the general disassembly of components that are required from installment.
Cosa ti serve
Unscrew the two screws on the antenna unit using a torc-head screwdriver.
Gently pry open the antenna unit with your fingers.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Slide out the inner casing attached to the antenna body.
Remove the rotating joint connecting the antenna casing to the main device:
Squeeze tweezers into the shown location and compress the spring.
Lift out the outer casing while keeping the spring compressed.
Altre 2 persone hanno completato questa guida.
