Salta al contenuto principale
GameStop Universal System Selector Button Replacement
Cosa ti serve
  1. GameStop Universal System Selector Button Replacement, Button: passo 1, immagine 1 di 1
    • Disconnect the DC 6V IN power cable from the device.
    • Remove the three front panel screws on the bottom of the device using the Phillips #00 Screwdriver.
  2. GameStop Universal System Selector Button Replacement: passo 2, immagine 1 di 1
    • Carefully pry off the front panel of the device to reveal the button in need of replacement.
    • The outer piece of the device is plastic and may break it not carefully handled.
  3. GameStop Universal System Selector Button Replacement: passo 3, immagine 1 di 2 GameStop Universal System Selector Button Replacement: passo 3, immagine 2 di 2
    • Pull firmly on the button in need of replacement to free it from its housing.
  4. GameStop Universal System Selector Button Replacement: passo 4, immagine 1 di 1
    • Gently push the replacement button into the housing.
  5. GameStop Universal System Selector Button Replacement: passo 5, immagine 1 di 1
    • Snap the front panel back into place.
    • Replace the 3 front panel screws.
Conclusione
The system selector button should now be working properly. Take your e-waste to an R2 or e-Stewards certified recycler.
Jared
Membro da: 10/28/13
201 Reputazione
2 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 565
