Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
The screen cover is the plastic window in front of the LCD screen. This guide shows how to replace the screen cover of the Game Boy Color.
  1. Locate the battery compartment on the back of the Game Boy Color. Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Remove the batteries from the battery compartment.
    • Remove the batteries from the battery compartment.
  3. Using a Y1 screwdriver, remove the six screws on the back of the device as pictured.  The bottom two screws are located inside of the battery compartment.
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
  4. Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out! Gently lift and separate the back housing from the rest of the device.  Now you've got the back housing out!
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture. Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    It’s not mentioned here, but be sure to unplug the LCD flex cable at the top of the motherboard before removing the motherboard. To do so, gently press the clips on either side of the receptacle toward the top of the Game Boy. When they are both pressed up, the orange cable will slide freely out
    Ben Perkins - Replica
    Thanks Ben. That's a very good point. Just ripping it out will cost you a couple bucks, not to mention your Gameboy will not work until you replace that ribbon cable.
    Chris Pavlik - Replica
  6. Gently lift the motherboard from the front housing.
    • Gently lift the motherboard from the front housing.
  7. Carefully slide a razor blade under one of the corners of the screen cover.
    • Carefully slide a razor blade under one of the corners of the screen cover.
  8. Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
    • Carefully lift up on the corner of the screen until you can grab the corner with your fingers.
    • Continue gently pulling up on the cover until it is fully removed.
Conclusione
Altre 16 persone hanno completato questa guida.
Cal Poly, Team 19-47, Regan Winter 2013 Membro di Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 Membri
34 Guide realizzate
bro, you mustn't to dismount the console to only remove the old lend
sdfsafas - Replica
You only need step 7 and 8.
h027299c - Replica
An alternative method is to in step 7 insert a small screwdriver into the hole in the front shell where the power light goes through and push off the screen enough to pry it off with your hands. Thereby avoiding this razor-near-the-screen business. You will also most likely need some alcohol (or similar) to loosen the residue leftover from the old screen.
Nick G - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 26
Ultimi 30 Giorni: 115
Tutti i Tempi: 14,935
