Salta al contenuto principale
GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement
Cosa ti serve
  1. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: passo 1, immagine 1 di 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: passo 1, immagine 2 di 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery Compartment Cover: passo 1, immagine 3 di 3
    • Find the battery compartment on the bottom of the clock radio.
    • Using your thumb, push the compartment cover latch toward the battery.
    • With the latch pushed in, pull the compartment cover upward to remove it..
  2. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: passo 2, immagine 1 di 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Battery: passo 2, immagine 2 di 2
    • Lift the battery from the compartment.
    • Pull the battery up and gently disconnect it from the battery connector.
  3. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: passo 3, immagine 1 di 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Screws: passo 3, immagine 2 di 2
    • Using a Phillips #00 Screwdriver, unscrew the six 12mm screws from around the bottom of the clock radio.
  4. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, LCD Cover: passo 4, immagine 1 di 1
    • Gently pull the liquid crystal display (LCD) cover off.
  5. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: passo 5, immagine 1 di 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Clock Radio: passo 5, immagine 2 di 2
    • Lift the top off. Two gray, plastic internal pieces will fall out when you do this; set them aside.
  6. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: passo 6, immagine 1 di 2 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker: passo 6, immagine 2 di 2
    • Grip the speaker.
    • Lift the speaker from the holder.
    • Turn the speaker over.
  7. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: passo 7, immagine 1 di 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: passo 7, immagine 2 di 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, Speaker from Wires: passo 7, immagine 3 di 3
    • The red wire is the + and the tan wire is the -. These wires are connected with solder.
    • Apply the hot soldering iron tip to the speaker connection solder.
    • Pull the speaker away from the wires.
  8. GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: passo 8, immagine 1 di 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: passo 8, immagine 2 di 3 GE 7-4836B Alarm Clock AM-FM Radio Speaker Replacement, New Speaker: passo 8, immagine 3 di 3
    • Attach a new 65 mm speaker, model #115048352530, with the wire connectors. Match the red wire to the + and the tan wire to the -.
    • Solder the wires to connect. Let the solder cool.
    • Reverse Step 6 to insert the new speaker in holder.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,947
