Introduzione
This is a guide showing you how to remove the Fusion5 5.5 Gen II motherboard to access certain components. Please note that this is not a guide for full disassembly of each component. Be sure to turn off the device before you start the first step and don’t forget to ground yourself.
Cosa ti serve
Hold the device with the screen facing away from you and the back of the device facing you.
Locate the groove at the bottom corner of the device.
Begin prying the back cover of the device off from the groove and working your way around the outside edges of the device.
Remove thirteen 3mm Phillips #00 screws from the midframe.
Remove the single 5mm Phillips #0 screw below the camera.
Using tweezers, flip the brown tab securing the ribbon cable.
Grab the ribbon cable with the tweezers and pull it from its socket on the motherboard.
