Salta al contenuto principale
Fujifilm FinePix Z1 LCD Screen Replacement
Cosa ti serve
  1. Fujifilm FinePix Z1 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Ensure that the camera is charged and not on PowerSave mode.
    • If the camera is charged and on, a faulty LCD Screen could be caused by a scratch or water damage. Also, trauma to the camera could cause the screen to shatter. In any of these cases, the screen will need to be replaced.
    • Make sure that the orange thin cable is appropriately attached.
  2. Fujifilm FinePix Z1 LCD Screen Replacement: passo 2, immagine 1 di 3 Fujifilm FinePix Z1 LCD Screen Replacement: passo 2, immagine 2 di 3 Fujifilm FinePix Z1 LCD Screen Replacement: passo 2, immagine 3 di 3
    • Open the camera by removing the 5 external 4.0 mm screws with the 1.0 flathead.
  3. Fujifilm FinePix Z1 LCD Screen Replacement: passo 3, immagine 1 di 2 Fujifilm FinePix Z1 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Gently pull the components apart.
    • Remove the 2.0mm screw to the left of the SD card.
    • The LCD screen is located on the back of the circuit board and can be accessed after removing the internal components.
  4. Fujifilm FinePix Z1 LCD Screen Replacement: passo 4, immagine 1 di 3 Fujifilm FinePix Z1 LCD Screen Replacement: passo 4, immagine 2 di 3 Fujifilm FinePix Z1 LCD Screen Replacement: passo 4, immagine 3 di 3
    • Use the PH00 to pry open the display screen of the camera.
    • Expose the display screen and make sure the cable connecting the screen and the camera are separated. Remember where the cable connection is located to attach the replacement screen.
    • Use the How to Solder and Desolder Connections Guide to remove the screen from the device.
Conclusione
Carra
Membro da: 01/30/18
533 Reputazione
4 Guide realizzate
Baylor, Team S2-G4, Johnson Spring 2018 Membro di Baylor, Team S2-G4, Johnson Spring 2018
BU-JOHNSON-S18S2G4
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 15
Tutti i Tempi: 583
