Salta al contenuto principale
FujiFilm FinePix S5100 Back Cover Replacement
Cosa ti serve
  1. FujiFilm FinePix S5100 Back Cover Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure your camera is in the off position.
    • Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
    • Open the battery door by pushing down and in the direction of the arrow on the door.
  2. FujiFilm FinePix S5100 Back Cover Replacement: passo 3, immagine 1 di 1
    • Remove four AA batteries from the camera.
  3. FujiFilm FinePix S5100 Back Cover Replacement, Back Cover: passo 4, immagine 1 di 1
    • Turn the camera so the screen is facing you and the camera lens is facing away from you.
  4. FujiFilm FinePix S5100 Back Cover Replacement: passo 5, immagine 1 di 3 FujiFilm FinePix S5100 Back Cover Replacement: passo 5, immagine 2 di 3 FujiFilm FinePix S5100 Back Cover Replacement: passo 5, immagine 3 di 3
    • Remove two 0.9mm Phillips #000 screws from the right side of the camera.
    • Remove one 0.6mm Phillips #000 screw from the left side of the camera.
    • Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
    • When replacing the back cover on the camera, there will be an audible click which ensures the cover has completely seated with the rest of the camera.
  5. FujiFilm FinePix S5100 Back Cover Replacement: passo 6, immagine 1 di 3 FujiFilm FinePix S5100 Back Cover Replacement: passo 6, immagine 2 di 3 FujiFilm FinePix S5100 Back Cover Replacement: passo 6, immagine 3 di 3
    • Carefully pull the back cover and separate it from the rest of the camera body.
    • Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
85.263 Reputazione
215 Guide realizzate
iFixit Membro di iFixit
Staff
140 Membri
18.146 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 206
