Salta al contenuto principale
Framework Laptop 16" Touchpad Spacers Replacement
  1. Framework Laptop 16" Touchpad Spacers Replacement, Before you begin: passo 1, immagine 1 di 2 Framework Laptop 16" Touchpad Spacers Replacement, Before you begin: passo 1, immagine 2 di 2
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Framework Laptop 16" Touchpad Spacers Replacement, Unlock the Input Modules: passo 2, immagine 1 di 3 Framework Laptop 16" Touchpad Spacers Replacement, Unlock the Input Modules: passo 2, immagine 2 di 3 Framework Laptop 16" Touchpad Spacers Replacement, Unlock the Input Modules: passo 2, immagine 3 di 3
    • Use your fingernail to pull out the two Input Module latches and unlock them.
    • The latch will show red if it's unlocked.
  3. Framework Laptop 16" Touchpad Spacers Replacement, Remove the touchpad spacers: passo 3, immagine 1 di 3 Framework Laptop 16" Touchpad Spacers Replacement, Remove the touchpad spacers: passo 3, immagine 2 di 3 Framework Laptop 16" Touchpad Spacers Replacement, Remove the touchpad spacers: passo 3, immagine 3 di 3
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  4. Framework Laptop 16" Touchpad Spacers Replacement: passo 4, immagine 1 di 1
    • Repeat the same procedure for the other touchpad spacer.
Conclusione
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
213.142 Reputazione
1.040 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.629 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 378
