Salta al contenuto principale
Framework Laptop 12 SSD Clip Replacement
Cosa ti serve
  1. Framework Laptop 12 SSD Clip Replacement, Power down your laptop: passo 1, immagine 1 di 3 Framework Laptop 12 SSD Clip Replacement, Power down your laptop: passo 1, immagine 2 di 3 Framework Laptop 12 SSD Clip Replacement, Power down your laptop: passo 1, immagine 3 di 3
    • Before you begin repairs, unplug your laptop and shut it down from the operating system. This ensures that the laptop isn't in standby/suspend mode.
    • The indicator LEDs along the edges should be unlit. The laptop should be silent.
    • If you accidentally turn on the laptop during repair, hold the power button down for 10 seconds to shut it down.
    • Make sure your Framework Screwdriver has the T5 Torx bit (labeled as T-5) facing outwards. If it's not, pull the bit out and flip it.
  2. Framework Laptop 12 SSD Clip Replacement, Set your laptop down: passo 2, immagine 1 di 1
    • Set your Framework Laptop face-down on a clean work surface.
  3. Framework Laptop 12 SSD Clip Replacement, Loosen the bottom screws: passo 3, immagine 1 di 2 Framework Laptop 12 SSD Clip Replacement, Loosen the bottom screws: passo 3, immagine 2 di 2
    • Use your Framework Screwdriver to fully loosen the eight captive T5 Torx screws on the bottom of your laptop.
    • Most screws in your Framework Laptop (including these) are captive—they're designed to stay in place after you loosen them.
  4. Framework Laptop 12 SSD Clip Replacement, Flip your laptop over: passo 4, immagine 1 di 1
    • Flip your laptop over so it's face-up on your work surface.
  5. Framework Laptop 12 SSD Clip Replacement, Open your laptop: passo 5, immagine 1 di 2 Framework Laptop 12 SSD Clip Replacement, Open your laptop: passo 5, immagine 2 di 2
    • Open the laptop lid so that both the screen and the base lie flat on your work surface.
  6. Framework Laptop 12 SSD Clip Replacement, Remove the Input Cover: passo 6, immagine 1 di 3 Framework Laptop 12 SSD Clip Replacement, Remove the Input Cover: passo 6, immagine 2 di 3 Framework Laptop 12 SSD Clip Replacement, Remove the Input Cover: passo 6, immagine 3 di 3
    • Use your fingers to grip the Input Cover in the hinge cutouts.
    • Lift upwards to swing the Input Cover up from the base of the laptop.
    • Magnets hold the Input Cover down, so you'll feel some resistance. If it feels stuck, check that you've fully loosened all the screws on the bottom of your laptop.
    • Remove the Input Cover.
  7. Framework Laptop 12 SSD Clip Replacement, Unlatch the SSD: passo 7, immagine 1 di 2 Framework Laptop 12 SSD Clip Replacement, Unlatch the SSD: passo 7, immagine 2 di 2
    • Use your finger to press down on the black SSD latch to unlatch the SSD.
    • The SSD will pop up to an angle when it's unlatched.
  8. Framework Laptop 12 SSD Clip Replacement, Remove the SSD: passo 8, immagine 1 di 3 Framework Laptop 12 SSD Clip Replacement, Remove the SSD: passo 8, immagine 2 di 3 Framework Laptop 12 SSD Clip Replacement, Remove the SSD: passo 8, immagine 3 di 3
    • Grab the SSD by its edges and pull it out of its socket.
    • Remove the SSD.
  9. Framework Laptop 12 SSD Clip Replacement, Remove the SSD clip screw: passo 9, immagine 1 di 1
    • Use your Framework Screwdriver to remove the 3.5 mm‑long T5 Torx screw securing the SSD clip.
    • This screw is not captive. Store it in a safe location for reassembly.
  10. Framework Laptop 12 SSD Clip Replacement, Remove the SSD clip: passo 10, immagine 1 di 2 Framework Laptop 12 SSD Clip Replacement, Remove the SSD clip: passo 10, immagine 2 di 2
    • Use your fingers to lift and remove the SSD clip.
  11. Framework Laptop 12 SSD Clip Replacement, Disassembly complete: passo 11, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Laptop.
  12. Framework Laptop 12 SSD Clip Replacement, Install the SSD clip: passo 12, immagine 1 di 2 Framework Laptop 12 SSD Clip Replacement, Install the SSD clip: passo 12, immagine 2 di 2
    • Align the SSD clip with its screw hole and set its two pins into their slots on the Mainboard.
  13. Framework Laptop 12 SSD Clip Replacement: passo 13, immagine 1 di 1
    • Use your Framework Screwdriver to install the 3.5 mm‑long T5 Torx screw to secure the SSD clip.
  14. Framework Laptop 12 SSD Clip Replacement, Install the SSD: passo 14, immagine 1 di 2 Framework Laptop 12 SSD Clip Replacement, Install the SSD: passo 14, immagine 2 di 2
    • Hold the SSD by its edges. Don't touch the gold contacts with your fingers. If you do, wipe the contacts with a clean, lint-free cloth to remove any finger oils.
    • Align the SSD's gold contacts with its socket.
    • Insert the SSD into the socket at a shallow angle. The gold contacts should mostly be covered by the socket.
    • The SSD fits into the socket in one orientation. If it doesn't feel like it fits, try flipping the module.
  15. Framework Laptop 12 SSD Clip Replacement: passo 15, immagine 1 di 3 Framework Laptop 12 SSD Clip Replacement: passo 15, immagine 2 di 3 Framework Laptop 12 SSD Clip Replacement: passo 15, immagine 3 di 3
    • Use your finger to press down on the black SSD latch to keep it open.
    • Use another finger to press the SSD down until it lays flat.
    • If the SSD doesn't fit in the latch, you may need to insert the SSD further into its socket.
    • Use your finger to close the latch to secure the SSD.
    • You should hear a click, and the SSD should no longer pop up.
  16. Framework Laptop 12 SSD Clip Replacement, Install the Input Cover: passo 16, immagine 1 di 3 Framework Laptop 12 SSD Clip Replacement, Install the Input Cover: passo 16, immagine 2 di 3 Framework Laptop 12 SSD Clip Replacement, Install the Input Cover: passo 16, immagine 3 di 3
    • Angle the bottom edge of the Input Cover towards the base of the laptop.
    • Align and insert the bottom edge of the Input Cover into the base of the laptop.
    • Make sure the slots along the bottom edge of the Input Cover slide into the tabs in the base.
    • Lower the Input Cover's top edge onto the laptop until the magnets snap it in place.
    • Make sure the Input Cover sits neatly within the laptop frame and no corners are popping up.
  17. Framework Laptop 12 SSD Clip Replacement, Close and flip your laptop: passo 17, immagine 1 di 2 Framework Laptop 12 SSD Clip Replacement, Close and flip your laptop: passo 17, immagine 2 di 2
    • Close the laptop lid.
    • Flip your laptop face-down on a clean work surface.
  18. Framework Laptop 12 SSD Clip Replacement, Tighten the bottom screws: passo 18, immagine 1 di 2 Framework Laptop 12 SSD Clip Replacement, Tighten the bottom screws: passo 18, immagine 2 di 2
    • Use your Framework Screwdriver to tighten the eight captive T5 Torx screws on the bottom of your laptop.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may strip the screws.
Conclusione
You finished fixing your Framework Laptop!
If you need help, contact Framework support.
Arthur Shi
Membro da: 01/03/18
313.387 Reputazione
729 Guide realizzate
Guide Team Membro di Guide Team
Staff
10 Membri
15.892 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 175
