Salta al contenuto principale
Framework Laptop 12 Fastener Guide
Cosa ti serve
  1. Framework Laptop 12 Fastener Guide, Fasteners information: passo 1, immagine 1 di 2 Framework Laptop 12 Fastener Guide, Fasteners information: passo 1, immagine 2 di 2
    • The Fastener Kit contains the following:
    • Grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head"
    • Silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head"
    • Black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head"
    • Gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head"
    • Silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head"
    • Silver screws labeled "M1.6 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head"
    • Your Framework Laptop comes with a spare screw of each size, attached to the chassis above the battery. You can use the Fastener Kit to replenish any screws you used there.
    Chiedi a FixBot
  2. Framework Laptop 12 Fastener Guide, Antenna screws: passo 2, immagine 1 di 3 Framework Laptop 12 Fastener Guide, Antenna screws: passo 2, immagine 2 di 3 Framework Laptop 12 Fastener Guide, Antenna screws: passo 2, immagine 3 di 3
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the antennas.
    Chiedi a FixBot
  3. Framework Laptop 12 Fastener Guide, Display screws: passo 3, immagine 1 di 2 Framework Laptop 12 Fastener Guide, Display screws: passo 3, immagine 2 di 2
    • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the display.
    • Tighten the screws until they're snug. Don't over-tighten them, or you may break the screw tabs.
    Chiedi a FixBot
  4. Framework Laptop 12 Fastener Guide, Expansion Card lock screws: passo 4, immagine 1 di 3 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: passo 4, immagine 2 di 3 Framework Laptop 12 Fastener Guide, Expansion Card lock screws: passo 4, immagine 3 di 3
    • Use the black screws labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the Expansion Card latches.
    • Use the silver screws labeled "M1.6 2.5mm fastener with a 3.5mm diameter 0.5mm thick T5 head" to replace the Expansion Card lock screws.
    Chiedi a FixBot
  5. Framework Laptop 12 Fastener Guide, Hinge screws (bottom): passo 5, immagine 1 di 3 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): passo 5, immagine 2 di 3 Framework Laptop 12 Fastener Guide, Hinge screws (bottom): passo 5, immagine 3 di 3
    • Use the silver screws labeled "M2 4.0mm fastener with a 4.6mm diameter 0.6mm thick T5 head" to secure the hinges to the Bottom Cover.
    Chiedi a FixBot
  6. Framework Laptop 12 Fastener Guide, Hinge screws (top): passo 6, immagine 1 di 3 Framework Laptop 12 Fastener Guide, Hinge screws (top): passo 6, immagine 2 di 3 Framework Laptop 12 Fastener Guide, Hinge screws (top): passo 6, immagine 3 di 3
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the hinges to the Top Cover.
    Chiedi a FixBot
  7. Framework Laptop 12 Fastener Guide, Power Button screw: passo 7, immagine 1 di 2 Framework Laptop 12 Fastener Guide, Power Button screw: passo 7, immagine 2 di 2
    • Use the grey screw labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the Power Button.
    Chiedi a FixBot
  8. Framework Laptop 12 Fastener Guide, SSD clip screw: passo 8, immagine 1 di 2 Framework Laptop 12 Fastener Guide, SSD clip screw: passo 8, immagine 2 di 2
    • Use the black screw labeled "M1.6 3.5mm fastener with a 3.0mm diameter 1.3mm thick T5 head" to secure the SSD clip.
    Chiedi a FixBot
  9. Framework Laptop 12 Fastener Guide, Touchpad screws: passo 9, immagine 1 di 3 Framework Laptop 12 Fastener Guide, Touchpad screws: passo 9, immagine 2 di 3 Framework Laptop 12 Fastener Guide, Touchpad screws: passo 9, immagine 3 di 3
    • Use the grey screws labeled "M1.6 1.5mm fastener with a 5.5mm diameter 0.6mm thick T5 head" to secure the touchpad.
    • Use the gold screws labeled "M2 2.0mm fastener with a 6.0mm diameter 0.5mm thick T5 head" to secure the touchpad pogo connector.
    Chiedi a FixBot
  10. Framework Laptop 12 Fastener Guide, Webcam screws: passo 10, immagine 1 di 2 Framework Laptop 12 Fastener Guide, Webcam screws: passo 10, immagine 2 di 2
    • Use the silver screws labeled "M2 2.8mm fastener with a 4.0mm diameter 0.5mm thick T5 head" to secure the webcam.
    Chiedi a FixBot
Conclusione
If you need help, contact Framework support.
Arthur Shi
Membro da: 01/03/18
335.951 Reputazione
848 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 22
Ultimi 30 giorni: 42
Tutti i Tempi: 205
