Salta al contenuto principale
FoodSaver V4980 Bag Cutter Replacement
  1. FoodSaver V4980 Bag Cutter Replacement, Bag Cutter: passo 1, immagine 1 di 1
    • The bag cutter is a small plastic rolling apparatus in the bag cutter arm.
    • Lift up the top cover to get to the bag cutter arm.
  2. FoodSaver V4980 Bag Cutter Replacement: passo 2, immagine 1 di 2 FoodSaver V4980 Bag Cutter Replacement: passo 2, immagine 2 di 2
    • Pull the sides of the cutter arm apart, and pull on the bag cutter to remove it from the arm.
Conclusione
Cal Poly, Team 34-17, Maness Spring 2016 Membro di Cal Poly, Team 34-17, Maness Spring 2016
CPSU-MANESS-S16S34G17
4 Membri
6 Guide realizzate
3 Commenti
how do i get a new one
Darlene Paulson - Replica
my bag cutter dont cut how do i get a new one & how much
my MACHINE IS BRAND NE, FIRST USE AND IT WILL NOT CUT
James Budelman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 37
Tutti i Tempi: 3,549
