Salta al contenuto principale
Fitbit Charge 2 Touch Screen Assembly Replacement
Cosa ti serve
  1. Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the watch band: passo 1, immagine 1 di 1
    • Before starting, take your Fitbit Charge 2 off the charger and power it down.
    • Remove the watch band on both sides.
  2. Fitbit Charge 2 Touch Screen Assembly Replacement, Heat the touch screen: passo 2, immagine 1 di 1
    • Heat an iOpener and apply it to the touch screen for two minutes.
    • The screen is not glued down, but the heat helps to loosen the touch screen assembly from your watch.
  3. Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the left edge: passo 3, immagine 1 di 3 Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the left edge: passo 3, immagine 2 di 3 Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the left edge: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iSesamo Opening Tool
    $9.99
    • Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
    • Slide the iSesamo along the left edge to the bottom left corner.
  4. Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the bottom edge: passo 4, immagine 1 di 2 Fitbit Charge 2 Touch Screen Assembly Replacement, Slide along the bottom edge: passo 4, immagine 2 di 2
    • Slide the iSesamo around the bottom left corner.
    • Slide it along the edge to the bottom right corner.
  5. Fitbit Charge 2 Touch Screen Assembly Replacement: passo 5, immagine 1 di 3 Fitbit Charge 2 Touch Screen Assembly Replacement: passo 5, immagine 2 di 3 Fitbit Charge 2 Touch Screen Assembly Replacement: passo 5, immagine 3 di 3
    • Slide the iSesamo around the bottom right corner.
    • Keep sliding it along the right edge to the top right corner.
  6. Fitbit Charge 2 Touch Screen Assembly Replacement: passo 6, immagine 1 di 2 Fitbit Charge 2 Touch Screen Assembly Replacement: passo 6, immagine 2 di 2
    • Slide the iSesamo around the top right corner.
    • Slide it along the top edge to the top left corner.
  7. Fitbit Charge 2 Touch Screen Assembly Replacement: passo 7, immagine 1 di 2 Fitbit Charge 2 Touch Screen Assembly Replacement: passo 7, immagine 2 di 2
    • Place the iSesamo under the top left corner.
    • Feel free to reattach the watch band for this and the next step for a better grip.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
  8. Fitbit Charge 2 Touch Screen Assembly Replacement: passo 8, immagine 1 di 2 Fitbit Charge 2 Touch Screen Assembly Replacement: passo 8, immagine 2 di 2
    • Place the iSesamo under the top right corner.
    • Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
  9. Fitbit Charge 2 Touch Screen Assembly Replacement: passo 9, immagine 1 di 2 Fitbit Charge 2 Touch Screen Assembly Replacement: passo 9, immagine 2 di 2
    • Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
    • Use the spudger to pry up the touch screen assembly.
    • Do not remove the touch screen assembly all the way yet—it's still connected to the motherboard.
  10. Fitbit Charge 2 Touch Screen Assembly Replacement: passo 10, immagine 1 di 1
    • Carefully fold the touch screen assembly in the direction of the bottom edge.
  11. Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the protecting sticker: passo 11, immagine 1 di 2 Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the protecting sticker: passo 11, immagine 2 di 2
    • Use a pair of blunt nosed tweezers to remove the black sticker which covering the touch screen connector.
  12. Fitbit Charge 2 Touch Screen Assembly Replacement, Open the ZIF connector: passo 12, immagine 1 di 2 Fitbit Charge 2 Touch Screen Assembly Replacement, Open the ZIF connector: passo 12, immagine 2 di 2
    • Use the pointed end of a spudger to open the ZIF connector by pushing up the black flap.
  13. Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the touch screen assembly: passo 13, immagine 1 di 3 Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the touch screen assembly: passo 13, immagine 2 di 3 Fitbit Charge 2 Touch Screen Assembly Replacement, Remove the touch screen assembly: passo 13, immagine 3 di 3
    • Pull the touch screen flex cable straight out its socket.
    • Remove the touch screen assembly.
Conclusione
If possible, turn on your device and test your repair before reassemble.
Opening didn’t go as planned? Ask our Answers community for help.
Altre 12 persone hanno completato questa guida.
Adriana Zwink
Membro da: 12/18/19
62.085 Reputazione
167 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.641 Guide realizzate
1Commento della guida
This is great
Mohsen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 87
Tutti i Tempi: 16,572
