Salta al contenuto principale
Epson VS240 Motherboard Replacement
Cosa ti serve
  1. Epson VS240 Motherboard Replacement, Shell: passo 1, immagine 1 di 3 Epson VS240 Motherboard Replacement, Shell: passo 1, immagine 2 di 3 Epson VS240 Motherboard Replacement, Shell: passo 1, immagine 3 di 3
    • Using the Phillips #2 screwdriver, loosen the single captive screw on the left side of the projector.
    • The captive screw will loosen, but it cannot be fully removed.
    • Slide the panel off and remove it from the device.
  2. Epson VS240 Motherboard Replacement: passo 2, immagine 1 di 2 Epson VS240 Motherboard Replacement: passo 2, immagine 2 di 2
    • Use the Phillips #2 screwdriver to remove the three 5 mm screws.
    • Using the same Phillips #2 screwdriver, remove the single 8 mm silver screw.
  3. Epson VS240 Motherboard Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the two 10 mm silver screws from the bottom of the device.
  4. Epson VS240 Motherboard Replacement: passo 4, immagine 1 di 1
    • Use a Phillips #1 screwdriver to remove the single 10 mm screw where the panel was removed in Step 1.
    • Remove the white back plate from the device.
  5. Epson VS240 Motherboard Replacement: passo 5, immagine 1 di 3 Epson VS240 Motherboard Replacement: passo 5, immagine 2 di 3 Epson VS240 Motherboard Replacement: passo 5, immagine 3 di 3
    • Flip the projector over so that the underside (side with the feet) is facing you.
    • Use a Phillips #1 screwdriver to remove five 10 mm screws on the underside of projector.
    • Using the same Phillips #1 screwdriver, remove a single 10 mm screw in the center hole.
    • You may need to use a screwdriver extender to reach the single screw.
  6. Epson VS240 Motherboard Replacement: passo 6, immagine 1 di 3 Epson VS240 Motherboard Replacement: passo 6, immagine 2 di 3 Epson VS240 Motherboard Replacement: passo 6, immagine 3 di 3
    • Use a Phillips #1 screwdriver to remove two 10 mm screws from the openings on each side of the air filter, on the topside of the projector.
    • You may need to use a screwdriver extender to reach the two screws.
    • Using the same Phillips #1 screwdriver, remove the two 10 mm screws where the white panel was removed on the topside of the projector in Step 1.
  7. Epson VS240 Motherboard Replacement: passo 7, immagine 1 di 2 Epson VS240 Motherboard Replacement: passo 7, immagine 2 di 2
    • Be careful when removing the top cover of projector as there is as white ribbon cable connecting it to the motherboard.
    • Gently lift top cover and place it on its top next to the projector so that the ribbon has no tension on it.
    • Gently pull the brown tape connecting the cable to the motherboard and then remove the shell from the device.
  8. Epson VS240 Motherboard Replacement, Motherboard: passo 8, immagine 1 di 2 Epson VS240 Motherboard Replacement, Motherboard: passo 8, immagine 2 di 2
    • Using a spudger or a plastic opening tool, disconnect all of the wires connected to the motherboard.
  9. Epson VS240 Motherboard Replacement: passo 9, immagine 1 di 2 Epson VS240 Motherboard Replacement: passo 9, immagine 2 di 2
    • Using the Phillips #1 screwdriver, remove three 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove a single 10 mm screw in bottom right corner of motherboard.
  10. Epson VS240 Motherboard Replacement: passo 10, immagine 1 di 2 Epson VS240 Motherboard Replacement: passo 10, immagine 2 di 2
    • Using a spudger or your fingernails, lift up the black locking tabs and disconnect the three ribbon cables from the motherboard.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Using the Phillips #1 screwdriver, remove three 10 mm screws on the grey piece that is located on the side of the motherboard.
  11. Epson VS240 Motherboard Replacement: passo 11, immagine 1 di 1
    • Lift and remove the motherboard up and away from the device.
Conclusione
Daniel Scarnavack
Membro da: 09/28/21
109 Reputazione
1 Guida realizzata
Clemson, Team 5-3, Hunter Fall 2021 Membro di Clemson, Team 5-3, Hunter Fall 2021
CLEM-HUNTER-F21S5G3
5 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 315
