Salta al contenuto principale
Epson Powerlite 460 Filter Replacement
  1. Epson Powerlite 460 Filter Replacement, Filter: passo 1, immagine 1 di 1
    • Orient the device with the projection window on top with the name of the device right side up.
  2. Epson Powerlite 460 Filter Replacement: passo 2, immagine 1 di 1
    • Slide the air filter cover opener in the direction indicated by the arrow to release the air filter cover.
  3. Epson Powerlite 460 Filter Replacement: passo 3, immagine 1 di 2 Epson Powerlite 460 Filter Replacement: passo 3, immagine 2 di 2
    • Open the air filter cover by pulling the top down and away from the device.
  4. Epson Powerlite 460 Filter Replacement: passo 4, immagine 1 di 2 Epson Powerlite 460 Filter Replacement: passo 4, immagine 2 di 2
    • Pinch the air filter cover handle and gently pull the filter away from the device
    • This may take a small amount of force.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 173
