Salta al contenuto principale
Epson Powerlite 460 Fan Replacement
Cosa ti serve
  1. Epson Powerlite 460 Fan Replacement, Motherboard: passo 1, immagine 1 di 2 Epson Powerlite 460 Fan Replacement, Motherboard: passo 1, immagine 2 di 2
    • Orient the device so that the projection window is facing down and the bottom of the device is visible.
    • Remove the eleven 13.3mm screws using a Phillips #2 screwdriver.
    Chiedi a FixBot
  2. Epson Powerlite 460 Fan Replacement: passo 2, immagine 1 di 3 Epson Powerlite 460 Fan Replacement: passo 2, immagine 2 di 3 Epson Powerlite 460 Fan Replacement: passo 2, immagine 3 di 3
    • Flip the device over so that the projection window is facing up.
    • Slide the air filter cover opener in the direction indicated by the arrow to release the air filter cover.
    • Remove the air filter cover.
    Chiedi a FixBot
  3. Epson Powerlite 460 Fan Replacement: passo 3, immagine 1 di 2 Epson Powerlite 460 Fan Replacement: passo 3, immagine 2 di 2
    • Remove the two 13.3mm screws from the top cover above the air filter using a Phillips #2 screwdriver.
    • Remove one 13.3mm screw from above the connection panel using a Phillips #2 screwdriver.
    Chiedi a FixBot
  4. Epson Powerlite 460 Fan Replacement: passo 4, immagine 1 di 2 Epson Powerlite 460 Fan Replacement: passo 4, immagine 2 di 2
    • Remove the cover from the projector and set aside.
    • The cover will be connected by ribbon cables. You do not need to disconnect these to complete this repair, but it may make it easier.
    Chiedi a FixBot
  5. Epson Powerlite 460 Fan Replacement: passo 5, immagine 1 di 3 Epson Powerlite 460 Fan Replacement: passo 5, immagine 2 di 3 Epson Powerlite 460 Fan Replacement: passo 5, immagine 3 di 3
    • Use the opening tool to disconnect eleven clip cables on the motherboard.
    • These will be the colorful cables connected with white plastic clips.
    • Disconnect the black cable clip by pressing the side tabs. Use the opening tool to release the cable if it is difficult.
    • To disconnect the ribbon cables, use the opening tool to lift the locking flap on the connector and slide the cable back and out of the connector.
    Chiedi a FixBot
  6. Epson Powerlite 460 Fan Replacement: passo 6, immagine 1 di 1
    • Disconnect the clip cable from below the motherboard and behind the connection panel.
    Chiedi a FixBot
  7. Epson Powerlite 460 Fan Replacement: passo 7, immagine 1 di 3 Epson Powerlite 460 Fan Replacement: passo 7, immagine 2 di 3 Epson Powerlite 460 Fan Replacement: passo 7, immagine 3 di 3
    • Remove seven 8.1mm screws from the motherboard using a Phillips #2 screwdriver.
    • Remove the 8.1mm screw from the back of the projection panel below the motherboard using a Phillips #2 screwdriver.
    • Remove two 8.1mm screws from the front of the projection panel using a Phillips #2 screwdriver.
    Chiedi a FixBot
  8. Epson Powerlite 460 Fan Replacement: passo 8, immagine 1 di 1
    • Gently lift the motherboard out of the device.
    Chiedi a FixBot
  9. Epson Powerlite 460 Fan Replacement, Lens: passo 9, immagine 1 di 2 Epson Powerlite 460 Fan Replacement, Lens: passo 9, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove the two 9.1mm screws from the focus lever adjuster.
    • Remove the focus lever mechanism by sliding the metal rod out of the plastic lever and lifting out of the unit.
    Chiedi a FixBot
  10. Epson Powerlite 460 Fan Replacement: passo 10, immagine 1 di 2 Epson Powerlite 460 Fan Replacement: passo 10, immagine 2 di 2
    • Remove the two 13.3mm screws from the metal bracket surrounding the lens unit using a Phillips #0 screwdriver.
    • Remove the bracket.
    Chiedi a FixBot
  11. Epson Powerlite 460 Fan Replacement: passo 11, immagine 1 di 2 Epson Powerlite 460 Fan Replacement: passo 11, immagine 2 di 2
    • Remove the two 13.3mm screws from the lens cover using a Phillips #0 screwdriver.
    • Use your finger to release the clips on either side of the lens cover.
    • Lift the lens cover to remove it from the projector.
    Chiedi a FixBot
  12. Epson Powerlite 460 Fan Replacement: passo 12, immagine 1 di 2 Epson Powerlite 460 Fan Replacement: passo 12, immagine 2 di 2
    • Remove the five 9.4mm screws from the lens using a Phillips #0 screwdriver.
    • Lift the lens out of the unit.
    Chiedi a FixBot
  13. Epson Powerlite 460 Fan Replacement, Fan: passo 13, immagine 1 di 2 Epson Powerlite 460 Fan Replacement, Fan: passo 13, immagine 2 di 2
    • Remove the two 13.3 mm screws on the parabolic dish/mirror.
    • Pull out the parabolic dish/mirror.
    Chiedi a FixBot
  14. Epson Powerlite 460 Fan Replacement: passo 14, immagine 1 di 1
    • Remove the four 13.4 mm screws from the fan cover.
    Chiedi a FixBot
  15. Epson Powerlite 460 Fan Replacement: passo 15, immagine 1 di 2 Epson Powerlite 460 Fan Replacement: passo 15, immagine 2 di 2
    • Remove the two 13.3 mm screws from the side of the air filter cover.
    Chiedi a FixBot
  16. Epson Powerlite 460 Fan Replacement: passo 16, immagine 1 di 2 Epson Powerlite 460 Fan Replacement: passo 16, immagine 2 di 2
    • Remove the two 13.4 mm screws from the fan.
    • Remove the fan.
    Chiedi a FixBot
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 626
