Salta al contenuto principale
Epson Powerlite 410W Lamp Replacement
Cosa ti serve
  1. Epson Powerlite 410W Lamp Replacement, Lamp: passo 1, immagine 1 di 1
    • Press the power button located on top of the projector.
    • Remember to let the projector cool off completely after turning off the power before beginning the repair.
  2. Epson Powerlite 410W Lamp Replacement: passo 2, immagine 1 di 3 Epson Powerlite 410W Lamp Replacement: passo 2, immagine 2 di 3 Epson Powerlite 410W Lamp Replacement: passo 2, immagine 3 di 3
    • Loosen the single captive screw holding the lamp cover in place using a Phillips #2 screwdriver.
    • Slide the cover out, then lift it off and place to the side.
  3. Epson Powerlite 410W Lamp Replacement: passo 3, immagine 1 di 1
    • Loosen the two captive screws that hold the lamp in place using a Phillips #2 screwdriver.
  4. Epson Powerlite 410W Lamp Replacement: passo 4, immagine 1 di 1
    • Use your hands to pull the lamp straight out of the projector.
    • When inserting the new lamp, push the lamp down firmly, where the label “PUSH” appears.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 261
