Salta al contenuto principale
Epson PowerLite 83+ Projector Lens Replacement
Cosa ti serve
  1. Epson PowerLite 83+ Projector Lens Replacement, Motherboard: passo 1, immagine 1 di 3 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: passo 1, immagine 2 di 3 Epson PowerLite 83+ Projector Lens Replacement, Motherboard: passo 1, immagine 3 di 3
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
  2. Epson PowerLite 83+ Projector Lens Replacement: passo 2, immagine 1 di 3 Epson PowerLite 83+ Projector Lens Replacement: passo 2, immagine 2 di 3 Epson PowerLite 83+ Projector Lens Replacement: passo 2, immagine 3 di 3
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
  3. Epson PowerLite 83+ Projector Lens Replacement: passo 3, immagine 1 di 2 Epson PowerLite 83+ Projector Lens Replacement: passo 3, immagine 2 di 2
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
  4. Epson PowerLite 83+ Projector Lens Replacement: passo 4, immagine 1 di 3 Epson PowerLite 83+ Projector Lens Replacement: passo 4, immagine 2 di 3 Epson PowerLite 83+ Projector Lens Replacement: passo 4, immagine 3 di 3
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
  5. Epson PowerLite 83+ Projector Lens Replacement: passo 5, immagine 1 di 3 Epson PowerLite 83+ Projector Lens Replacement: passo 5, immagine 2 di 3 Epson PowerLite 83+ Projector Lens Replacement: passo 5, immagine 3 di 3
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
  6. Epson PowerLite 83+ Projector Lens Replacement: passo 6, immagine 1 di 2 Epson PowerLite 83+ Projector Lens Replacement: passo 6, immagine 2 di 2
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
  7. Epson PowerLite 83+ Projector Lens Replacement: passo 7, immagine 1 di 2 Epson PowerLite 83+ Projector Lens Replacement: passo 7, immagine 2 di 2
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
  8. Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: passo 8, immagine 1 di 3 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: passo 8, immagine 2 di 3 Epson PowerLite 83+ Projector Lens Replacement, Projector Lens: passo 8, immagine 3 di 3
    • Remove the four 6 mm Phillips #2 screws securing the fan bracket.
    • Remove the fan bracket by pulling straight up and set it aside.
  9. Epson PowerLite 83+ Projector Lens Replacement: passo 9, immagine 1 di 3 Epson PowerLite 83+ Projector Lens Replacement: passo 9, immagine 2 di 3 Epson PowerLite 83+ Projector Lens Replacement: passo 9, immagine 3 di 3
    • Remove the four 6 mm Phillips #2 screws securing the projector lens.
  10. Epson PowerLite 83+ Projector Lens Replacement: passo 10, immagine 1 di 2 Epson PowerLite 83+ Projector Lens Replacement: passo 10, immagine 2 di 2
    • Unhook the JST connector wire from wire stay and move it aside.
    • Remove the projector lens from the base.
Conclusione
Billy Fox
Membro da: 02/22/22
467 Reputazione
3 Guide realizzate
Clemson, Team 2-4, Hunter Spring 2022 Membro di Clemson, Team 2-4, Hunter Spring 2022
CLEM-HUNTER-S22S2G4
4 Membri
6 Guide realizzate
1Commento della guida
source for a replacement lens? I surely need one.
christopher wanko - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 21
Tutti i Tempi: 724
