Salta al contenuto principale
Epson PowerLite 822 Plus Lamp Replacement
Cosa ti serve
  1. Epson PowerLite 822 Plus Lamp Replacement, Lamp: passo 1, immagine 1 di 1
    • If you just used the projector you will want to let it sit for about an hour to cool off.
    • If you have not used the projector within the past few hours you are ready to get to work.
  2. Epson PowerLite 822 Plus Lamp Replacement: passo 2, immagine 1 di 2 Epson PowerLite 822 Plus Lamp Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the 6 mm screw that holds the lamp cover in place.
  3. Epson PowerLite 822 Plus Lamp Replacement: passo 3, immagine 1 di 3 Epson PowerLite 822 Plus Lamp Replacement: passo 3, immagine 2 di 3 Epson PowerLite 822 Plus Lamp Replacement: passo 3, immagine 3 di 3
    • Apply pressure to the lamp cover, pulling it towards the end of the projector.
    • Pop the lamp cover off, exposing the lamp.
  4. Epson PowerLite 822 Plus Lamp Replacement: passo 4, immagine 1 di 3 Epson PowerLite 822 Plus Lamp Replacement: passo 4, immagine 2 di 3 Epson PowerLite 822 Plus Lamp Replacement: passo 4, immagine 3 di 3
    • There are two 9mm screws which have already been loosened. These screws do not come all the way out.
    • Grip the finger hold and pull it straight out of the projector.
  5. Epson PowerLite 822 Plus Lamp Replacement: passo 5, immagine 1 di 1
    • After pulling it straight up by the finger hold the lamp will be revealed and ready to be replaced.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 128
