Cosa ti serve
Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
Lift the top panel up.
Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
Remove the top panel.
