Salta al contenuto principale
Epson PowerLite 77c Front Remote Sensor Replacement
Cosa ti serve
  1. Epson PowerLite 77c Front Remote Sensor Replacement, Top Panel: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
  2. Epson PowerLite 77c Front Remote Sensor Replacement: passo 2, immagine 1 di 2 Epson PowerLite 77c Front Remote Sensor Replacement: passo 2, immagine 2 di 2
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
  3. Epson PowerLite 77c Front Remote Sensor Replacement, Front Remote Sensor: passo 3, immagine 1 di 1
    • Grip the front remote sensor's white plug and gently pull directly upwards until the plug releases.
  4. Epson PowerLite 77c Front Remote Sensor Replacement: passo 4, immagine 1 di 1
    • Lift the remote sensor up and out of the projector.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 13
Tutti i Tempi: 162
