Introduzione
The fan is an essential component to keep your projector cool and functional. Before replacement, first check if there is dirt or dust clogging the fan's blades. Use an ESD-safe brush and/or compressed air to remove any dirt or dust buildup, then test the projector. If cleaning didn't solve the problem, and/or damage is visible, replacing the fan is the next best step. Before replacing the fan, make sure the projector is turned off, and allow it to cool completely before beginning.
Cosa ti serve
Use a Phillips #0 screwdriver to remove the one 5.0 mm screw from the lamp cover on the back of the device.
Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
Lift the top panel up.
Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
Remove the top panel.
