Salta al contenuto principale
Envizen V100M Speakers Replacement
Cosa ti serve
  1. Envizen V100M Speakers Replacement, Back Cover: passo 1, immagine 1 di 2 Envizen V100M Speakers Replacement, Back Cover: passo 1, immagine 2 di 2
    • Remove the two screws on the side of the tablet that hold the back cover in place using the ifixit PH00 screwdriver.
    • The two screws for the back cover are: 1.5mm diameter x 3.5mm long
  2. Envizen V100M Speakers Replacement: passo 2, immagine 1 di 3 Envizen V100M Speakers Replacement: passo 2, immagine 2 di 3 Envizen V100M Speakers Replacement: passo 2, immagine 3 di 3
    • Pry along the edge of the device to separate the back cover from the device.
    • The speakers are attached to the back cover and motherboard assembly so remove carefully.
  3. Envizen V100M Speakers Replacement, Speakers: passo 3, immagine 1 di 1
    • Check to see if the wires of the speakers are connected to the motherboard assembly here.
  4. Envizen V100M Speakers Replacement: passo 4, immagine 1 di 1
    • take the wires of one of the speakers and solder them back on the mother board, as shown. Remember, Red is always positive (+) and Black is always negative (-). here is a guide on how to solder.
  5. Envizen V100M Speakers Replacement: passo 5, immagine 1 di 1
    • Repeat the same process for the second speaker. The other set of terminals for the second speaker is directly next to the first set.
Conclusione
nbach
Membro da: 03/23/15
663 Reputazione
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 118
