Introduzione
This guide will help in safely accessing and replacing the battery in the Ematic Genesis tablet.
Cosa ti serve
Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
Lift up the two pieces of tape holding the copper plate and the connector ribbon to the battery. Gently hold or place away from the battery.
Using a plastic card, gently break the adhesive that holds the battery to the metal screen plate.
If replacing the battery, disconnect the wires that connect the battery to the motherboard.
If not replacing the battery, do NOT disconnect the wires.
