Salta al contenuto principale
Ematic FunTab 2 Motherboard Replacement
Cosa ti serve
  1. Ematic FunTab 2 Motherboard Replacement, Motherboard: passo 1, immagine 1 di 1
    • Remove back of Ematic FunTab by using the plastic opening tool to pry the back open.
  2. Ematic FunTab 2 Motherboard Replacement: passo 2, immagine 1 di 3 Ematic FunTab 2 Motherboard Replacement: passo 2, immagine 2 di 3 Ematic FunTab 2 Motherboard Replacement: passo 2, immagine 3 di 3
    • Next, you need to remove all connections to the motherboard and the device.
    • Start by first removing the tape from all the connections.
    • Be careful not to remove the camera.
  3. Ematic FunTab 2 Motherboard Replacement: passo 3, immagine 1 di 3 Ematic FunTab 2 Motherboard Replacement: passo 3, immagine 2 di 3 Ematic FunTab 2 Motherboard Replacement: passo 3, immagine 3 di 3
    • Remove LCD connector from the LCD.
    • Be sure to flip up the retaining tabs before pulling the LCD connector out. (It is the black tab on the connection port).
  4. Ematic FunTab 2 Motherboard Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove camera connection from camera with tweezers.
    • Again, be sure to flip up the retaining tab before pulling the connector.
  5. Ematic FunTab 2 Motherboard Replacement: passo 5, immagine 1 di 1
    • Remove speaker connection from speaker with tweezers.
    • Before pulling the speaker connection make sure the retaining tab is flipped up.
  6. Ematic FunTab 2 Motherboard Replacement: passo 6, immagine 1 di 3 Ematic FunTab 2 Motherboard Replacement: passo 6, immagine 2 di 3 Ematic FunTab 2 Motherboard Replacement: passo 6, immagine 3 di 3
    • Remove wires:
    • Start by removing the black wire on each side.
    • Next, remove the WiFi antenna wire from the motherboard.
    • Finally, remove the yellow, red, and black wires.
    • To put the wires back in their correct locations you will need a soldering iron to solder the wire back in place. You will do this once the motherboard is replaced. Here is a guide on how to solder Come saldare e dissaldare componenti elettrici
  7. Ematic FunTab 2 Motherboard Replacement: passo 7, immagine 1 di 3 Ematic FunTab 2 Motherboard Replacement: passo 7, immagine 2 di 3 Ematic FunTab 2 Motherboard Replacement: passo 7, immagine 3 di 3
    • Unscrew all four screws on motherboard with the Phillip's head screwdriver.
    • All of the screws are the same size, and should all fit in either corresponding screw location.
  8. Ematic FunTab 2 Motherboard Replacement: passo 8, immagine 1 di 2 Ematic FunTab 2 Motherboard Replacement: passo 8, immagine 2 di 2
    • It is now safe to remove and replace the old motherboard with your new motherboard.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,130
